Your Aerodynamics are all Screwed Up
  • Context: Graduate
  • Thread starter Thread starter XP3Scorpion
    Aerodynamics
The discussion centers around aerodynamics, particularly the design principles of objects moving through viscous environments like air and water. Participants explore concepts related to shape efficiency, the role of spoilers in vehicle design, and claims regarding fuel efficiency in vehicles.
  • One participant asserts that objects should have their larger end leading to align with natural forces, citing biological examples like egg-laying in birds.
  • Another participant challenges the biological analogy, stating that birds do not have vaginas.
  • Some participants argue that the teardrop shape is the most efficient for subsonic travel, while others dispute the claim about spoilers, stating they are meant to reduce lift rather than drag.
  • Claims of achieving between 100 and 590 miles per gallon (mpg) in a vehicle are presented, with skepticism expressed by other participants regarding the validity of these claims.
  • One participant suggests that the high mpg claims could be attributed to refueling practices that might distort actual mileage calculations.
  • A later reply points out a mathematical error in the mpg claims, suggesting an even more extreme fuel consumption rate than initially stated.
  • Another participant expresses interest in attending a conference related to alternative energy technologies, indicating a connection to the broader themes of the discussion.
Participants express disagreement on several points, particularly regarding the validity of the mpg claims and the function of spoilers. There is no consensus on the correctness of the aerodynamic principles discussed.
Some claims rely on specific assumptions about vehicle operation and environmental interactions that are not fully explored. The discussion includes speculative ideas that remain unverified.
Readers interested in aerodynamics, vehicle design, alternative energy technologies, and the interplay between physics and engineering may find this discussion relevant.
XP3Scorpion
Your Aerodynamics are all Screwed Up!
Rule #1) Never should the small end of an object that is intended to travel through a viscous (sticky & elastic) environment e.g. air, water, electromagnetic-spectrum etc... precede the larger end, to do so places the moving object in opposition to natures cyclonic properties i.e. any object that has a smaller point in the front and a larger tail section in the rear is 180-degrees out of phase with the environment.
Comprehend and Copy Nature!
Anatomically speaking nature is female, and as such certain rules do apply.
Note: When a bird lays an "egg" the large end always proceeds the smaller end, otherwise the vaginal orifice can not "squeeze" the egg and expel it from the birthing canal. Said squeezing translates into either constructive or destructive force depending on the direction of the geometrical structure i.e. the shape of the object traveling through the environment, large end preceding the smaller tapered end thereby allowing the air, water, electromagnetic properties inherent within the environment to squeeze the object from an anterior location e.g. from back to front and not the other way round, which would initialize an antagonistic force against force, nature ultimately being the larger force.
Spoilers
In general the use of a spoiler on a car was intended to squeeze a jet of air from in-between the under surface of the wing and that of the car body, whereby practice drag in the form of eddy/vortices is pushed further away downstream form the rear of the car so as not to be allowed to pull backwards and thus detract from the overall froward travel of the vehicle. It should be borne of mind thou that is a brut force upon brut force measure, and as such goes against complementary energy transference technology. Remember parasitic drag is induced via the forward motion of the vehicle through the air. Therefor geometrical shapes plays a major role on the selective placement of the "squeeze-energy" either beneficially or antagonistically depending upon the shape of the craft.
This is where the "coke-bottle" shape of a supersonic platform and the area rule design come into play...
Oh! You think I'm wrong?
Then please explain to me how I managed to obtain 3-times my normal mileage driving in excess of 70-mph and how I managed to obtain between 100-and-590-mpg driving a sustained speed of 65-mph, applying the same principles cited above. http://quantumgravitics.tripod.com/
Birds don't have vaginas.
- Warren
Unless I'm misunderstanding you, what you're saying in the first part doesn't sound a whole lot different from what we already know: a teardrop shape is the most efficient subsonic shape. The second part about spoilers though is wrong: spoilers exist to "spoil" lift, not reduce drag.
Your claims about that van getting 100mpg, however are absolutely absurd.
Oh come on man.. check it out!
http://quantumgravitics.tripod.com//sitebuildercontent/sitebuilderpictures/riwfueltest.jpg
If that ain't the solution to the world's energy problems, I don't know what is!
- Warren
You filled up the tank with cold fuel from an underground tank, drove 20 miles and refilled it. Then went 59 miles, refilled, and have outrageoud MPG claims.
Ever just put your lawnmower's gas can in the sun after you've filled the mower and then to refill again? Ever had vapor lock after topping off you tank?
Cliff
Come on now, Cliff. This site isn't about that science baloney.
- Warren
Oh wow...
my first "move to TD" thread ever!
I feel so special.
*pushes button*
...Your claims about that van getting 100mpg, however are absolutely absurd.
But look! I've found an error. He says
59 miles @ 0.1 tenths of a gallon = 590-mpg!
0.1 tenths of a gallon is actually 0.01 gallon. So the actual fuel consumption rate is 5900 mpg! Wow. Now we're talking.
Where can I buy one?
2004 Extraordinary Technology Conference
Hello! :biggrin:
Everybody looks like Ill be attending the conference hosted by TeslaTech and the Institute of New Energy.
Steven R. Elswick of Extraordinary Technology Magazine has invited me to attend their prestigious technology conference. I will discus Vortex Mechanics Free Energy and the RIW of course Ill bring the QEG-circuit too working or not.
2004 Extraordinary Technology Conference :shy:
--- Conference Session 6 --- Alternative Energy Technology 2:30pm: Robert A. Patterson
http://www.teslatech.info/ttevents/2004conf/prgframe.htm Program Menu
http://www.teslatech.info/ttevents/2004conf/program11.pdf PDF article
Thank You
Robert A. Patterson
Engineering Specialist
  • · Replies 69 ·
18K
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 82 ·
29K
