What Is the Maximum Value of Dv f(1,2) and Its Corresponding Direction v?
The maximum value of the directional derivative Dv f(1,2) occurs when the direction vector v is aligned with the gradient of the function f at that point. Given the gradient f = (18, 9), the maximum value is equal to the magnitude of the gradient, which is |∇f(1,2)| = √(18² + 9²) = 20.25. The corresponding direction v is the unit vector in the direction of the gradient, calculated as v = (18/20.25, 9/20.25). This analysis clarifies the confusion regarding the notation Dv versus Du, as both refer to directional derivatives.
  • Understanding of directional derivatives in multivariable calculus
  • Familiarity with gradient vectors and their properties
  • Knowledge of unit vectors and dot products
  • Basic proficiency in calculating magnitudes of vectors
  • Study the concept of directional derivatives in more depth, focusing on their applications in optimization.
  • Learn how to compute gradients for various functions, particularly in two dimensions.
  • Explore the geometric interpretation of directional derivatives and gradients.
  • Investigate the relationship between directional derivatives and level curves of functions.
Students and professionals in mathematics, physics, and engineering who are working with multivariable calculus and need to understand directional derivatives and gradients for optimization problems.
team31
when u=-0.6i+0.8j, Du f(1,2)=? gradient f=(18,9)
I use unit vector dot (-0.6,0.8) dotted with the gradient f, which turns out to be -3.6
so here is the question. A: the maximum value of Dv f(1,2) is=?
B: this maximum occurs when v=(?,?)
I'm confued with the Dv thing. For my guess is that I should use (1,2) to creat a unit vector which is (1/sqrt5, 2/sqrt5), and use that unit vetor dotted with the gradient f, which gives me the maximum value of Dv f(1,2)
then i will find a vector that its dot product with ( 1/sqrt5, 2/sqrt5) is 0, and tha should be the direction of V which is the answer for part B
Am I doing this right? plaese help me out. I've been looking into my textbook but couldn't find the symbol Dv, they all used Du. Thank u
Directional Derivatives
Directional derivatives of $f(x,y)$ are, for unit vectors [tex]\vec{u}[/tex], are defined by:
[tex]D_{\vec{u}}f(x,y) = \vec{u}\cdot \vec{\nabla}f (x,y)[/tex]​
where [tex]\cdot[/tex] denotes the dot product. To see when the maximum value of the directional derivatives occurs, consider the magnitude of the directional derivative, recalling that [tex]\left|\vec{u}\cdot\vec{v} \right| = \left|\vec{u}\right|\cdot \left|\vec{v} \right|\cos \theta[/tex] where [tex]\theta[/tex] is the acute angle between the vectors we have that
[tex]\left| D_{\vec{u}}f(x,y)\right| = \left| \vec{u}\cdot \vec{\nabla}f (x,y)\right| = \left| \vec{u}\right|\cdot\left| \vec{\nabla}f (x,y)\right|\cos \theta = 1\cdot\left| \vec{\nabla}f (x,y)\right|\cos \theta = \left| \vec{\nabla}f (x,y)\right|\cos \theta[/tex]​
since [tex]\left| \vec{u}\right| =1[/tex] since [tex]\vec{u}[/tex] is a unit vector; consider that the quantity [tex]\left| \vec{\nabla}f (x,y)\right|\cos \theta[/tex] is maximized when [tex]\cos \theta =1[/tex], i.e. when [tex]\theta =0[/tex] namely when the vectors [tex]\vec{u}[/tex] and [tex]\vec{\nabla}f (x,y)[/tex] are paralell. This occurs if [tex]\vec{u} = \frac{\vec{\nabla}f (x,y)}{\left| \vec{\nabla}f (x,y)\right|}[/tex] which is a unit vector parallel to [tex]\vec{\nabla}f (x,y)[/tex]. The maximum value is then
[tex]D_{\frac{\vec{\nabla}f (x,y)}{\left| \vec{\nabla}f (x,y)\right|}}f(x,y) = \frac{\vec{\nabla}f (x,y)}{\left| \vec{\nabla}f (x,y)\right|}\cdot \vec{\nabla}f (x,y) = \frac{\left| \vec{\nabla}f (x,y)\right|^{2}}{\left| \vec{\nabla}f (x,y)\right|} = \left| \vec{\nabla}f (x,y)\right|[/tex]​
  • · Replies 16 ·
  • · Replies 21 ·
21K
29K
  • · Replies 22 ·
