Time Dilation Formula: Calculating Rel Speed Diff b/w Objects
The discussion revolves around the formula for calculating relative time speed differences between objects of unequal mass, specifically focusing on gravitational time dilation and its implications. Participants explore the relationship between mass, gravity, and time measurement, addressing both theoretical and practical aspects.
  • Some participants inquire about the formula for relative time differences between objects of unequal mass, suggesting a focus on gravitational time dilation.
  • Others clarify that gravitational time dilation is independent of mass and is instead related to the gravitational field strength experienced by an observer.
  • A participant shares a personal formula for time dilation based on earlier measurements, expressing interest in a more accurate and general formula applicable to various masses.
  • Several participants discuss the gravitational time dilation formula, questioning its variables and applicability under different conditions, such as when an observer is in motion or falling towards a massive object.
  • There is a distinction made between the behavior of atomic clocks and pendulum clocks in strong gravitational fields, with some arguing that the mechanisms behind their ticking rates differ significantly.
  • Concerns are raised about the interpretation of time dilation, with some suggesting that the effects observed may not represent overall time dilation but rather specific rates of oscillation influenced by gravity.
  • Questions arise regarding the relationship between mechanical forces and time measurement, particularly in the context of GPS technology and its reliance on Einsteinian time dilation.
Participants express differing views on the nature of time dilation, with some emphasizing the mechanical aspects of clock behavior while others advocate for a more nuanced understanding that includes relativistic effects. The discussion remains unresolved, with multiple competing perspectives presented.
Limitations include the dependence on specific definitions of time and gravity, as well as the unresolved nature of how different types of clocks respond to gravitational influences. The discussion also highlights the complexity of integrating classical mechanics with relativistic concepts.
mikesvenson
could someone tell me the formula to figure out how much relative time speed difference there is between two or more objects of unequal mass?
If you are referring to the Lorenz contraction of time with speed, it has nothing to do with mass.
Perhaps gravitational time dilation?
yes, gravitational time dilation. since an object of mass has gravity relative to its mass. more mass, more gravity.
years ago i made my own formula for this. A simple one dealing with just multiplication, division, and exponents. But it was based on an inacurate measurement of time dilation, and was only applicable to the Earths gravity, which was represented as a constant variable. I just did it out of interest. It was kinda cool cause it could tell you how much relative time difference there would be per inch per second from sea level.
so what's the real formula that I could apply to any object(s) of any mass(es)?
The gravitational time dilation formula is
[tex]T= \frac {T_{0}}{\sqrt{1- \frac{2GM}{Rc^{2}}}}[/tex]
R is the distance from the center of the object, or the radius of the object if you are considering a point on the surface of a spherical body.
T is time as measured from a point sufficiently removed from the gravity field of the object. (I.E. At an infinite distance form the object. )
so,
T = the relative time elapsed from the center of a massive object to an observer at a distance from the massive object?
To = the time on the observers watch?
G = Gravity? how do you calculate this?
M = mass? how do you calculate this?
C = light speed? I would assume...
does this formula only work if the observer is stationary relative to the massive object? what if the observer is maintaining a constant distance, but is orbiting at a speed? what if the observer is falling towards the object?
someone please explain this further, i never had an interest in math until recently
Originally posted by mikesvenson
so,
First off, please note that I have edited my response, to correct a typo. It is T that represents the time on the observers watch.
G is the Gravitational constant. Its value is aprox 0.00000000006673
M is the mass of the body, which you have to already know, or be able to measure.
R is the distance from the center of the mass the clock you are comparing the observer's clock is.
c is the speed of light in a vacuum.
So for a for a clock sitting on the surface of the Earth:
M = the mass of the Earth = 6 x 1024 kg
and
R = the radius of the Earth = 6378000 m
Plugging these numbers in will give you how much slower a clock on the surface of the Earth runs than our distantly removed observers.
If you raise the clock to a higher altitude, you increase R by the correct amount and recalculate.
For an circularly orbiting object you would use the gravitaional time dilation formula for its height, but then also factor in the SR time dilation due to its velocity.
If the object was falling straight down, then its time dilation would be changing from moment to moment, since both its velocity and distance from the center of the mass would be changing constantly.
This is not true overall “time dilation”. This is merely the rate an atomic clock will slow down in different gravitational potentials. This is based on a slow-down in the internal oscillation rates of the atoms. An atom existing in stronger gravity or accelerating will have a slower internal oscillation rate, but that rate doesn’t necessarily represent all of “time”, since time is also determined by other local factors, such as thermodynamics and mechanical motions in the same area where the atom is located. For example, a large oscillating mass, such as the bob on a pendulum clock, will oscillate faster in a strong gravity field, while an atom will oscillate internally more slowly. This is the difference between large-scale Newtonian mechanics and small-scale quantum mechanics. In addition, there is thermodynamic time, as seen in the external vibration rates of molecules and atoms. This kind of vibration rate and time often speeds up at the same places where internal atomic oscillation rates of atoms slows down, such as at the surface of a star.
does this mean that in a strong gravity field, a pendulum clock will tick faster and an atomic clock will tick slower?
Yes. This was known about pendulum clocks 400 years ago. It was not known about atomic clocks slowing down in a gravity field until Einstein deduced it in 1911. However, Lorentz, in 1895, deduced that atomic clocks would slow down when they moved rapidly through fields. So, now, with the combined theories of Einstein and Lorentz, we know that atomic clocks slow down in a gravity field and they slow down due to acceleration and when they move rapidly through fields.
This is basically “quantum mechanics”, the inner workings of atoms on the very small scale.
The speed-up of pendulum clocks in a strong gravity field works on a different principle. It is a large-scale phenomenon, so different laws govern the workings and tick rates of pendulum clocks.
It is generally only physicists and astronomers who think of “atomic time” as being “true time”. But if you go to Google and type in [biology “thermodynamic time”] you will see that biologists generally deal with thermodynamic time, i.e. heat energy time, rather than atomic time.
I maybe haven't been paying enough attention to your other posts (maybe you've discussed this before), but are you saying that an atomic clock sees its rate change for the same reason as a pendulum, ie. simply a matter of mechanical force and not real time dilation? If so, how do you reconcile that with the fact that the GPS system works and is based on Einsteinian time dilation, not mechanical clock rate issues?
Also, not all oscillations are affected by gravity. A spring-mass system perpendicular to a gravitational force is not affected by the strength of the force.
Time dilation in general relativity is a bit more complicated than an equation that can be fully explained in a brief posting to a message board. The cliff note version of the answer is that the invariant interval or line element ds in [tex]ds^2 = g_{\mu}_{\nu}dx^{\mu}dx^{\nu}[/tex] is the length of time [tex](ds = dc\tau)[/tex] that goes by for something following that path. Your coordinate time is in the right hand side of the equation as [tex]dct = dx^0[/tex] and that will give you a differential equaion relating the times that is valid even if a real force is applied so that the motion is not geodesic. The metric [tex]g_{\mu}_{\nu}[/tex] for arbitrary numbers of gravitational sources is related by second order nonlinear differential equations to those sorces through Einstein's field equations. Finding exact solutions isn't always feasible so usually a linearized weak field approximation is made in which case one can simply input the Newtonian gravitational potential into places in the metric and get an approximate answer. If the motion is geodesic, then one may also refer to the equation of geodesic motion which will in some few cases yield the result strait away or eliminate coordinate variables from the expression for the line element.
HOLY SH*T!
DID YOU BREATH AT ALL WHILE YOU TYPED THAT??
THIS IS SOOOOOOOOOO OVER MY HEAD I DONT EVEN KNOW !
I THOUGHT I HAD THIS DOG ON A LEASH BUT IT GOT AWAY!
WHEW!
TIME FOR ME TO GO BACK TO COLLAGE AND MAJOR IN PHYSICS SO I CAN COMPREHEND WHAT YOU ARE TALKING ABOUT!PEACE!
Well, Russ, it’s kind of complicated and difficult to explain briefly. First, it was H.A. Lorentz, not Einstein, who first invented the concept of “atomic” time dilation. The concept of “atomic time” first came from Maxwell in 1873. You can find it mentioned on page 3 of the first volume of his famous “Treatise on Electricity and Magnetism”. Atomic time is based on the frequency of light given off by an oscillating atom, and the frequency of that light is determined by the oscillation frequency of the atom. Lorentz hypothesized in his 1895 book, “Versuch Einer Theorie Der Elektrischen Und Optischen Erscheninungen In Bewegten Körpen,” that the oscillation frequency of an atom could slow down if the atom moved through certain fields and if it was subjected to acceleration. In 1911 Einstein deduced that motion-related acceleration was quite similar to gravitational acceleration, so he extended Lorentz theory to include a slow-down in the oscillation rates of atoms that existed in a gravity field. We can’t say “atoms resting in a gravity field” since atoms don’t “rest”, they move around rather quickly because of heat energy, i.e. molecular vibrations.
Ok, so, since atomic oscillation rates tend to be very steady, if a collection of atoms are not moving rapidly through fields, not changing RMS acceleration rates due to temperature changes, and not changing altitudes or gravitational potentials, atomic clocks eventually became our “time base standard” for measuring very accurate and short time durations.
The work of both Lorentz and Einstein had already predicted that moving atomic clocks and atomic clocks that change altitudes would change their oscillation rates, their “tick rates”, so this was no surprise when the GPS satellites were first sent up. But there are also additional factors that contribute to atomic oscillation rate changes, such as temperature changes within the collection of atoms that are being monitored inside the clock. This is because higher temperatures cause higher RMS speeds of the bouncing atoms, and this causes greater accelerations when the bouncing atoms change directions. Also, they tend to change their rates when they move through magnetic and electric fields, and thus they have to be shielded as much as possible from these fields. But they can’t be shielded from gravity fields.
An atomic oscillation rate does not change for the same reason a pendulum bob changes its swing rate. That’s because there are different laws of physics at work in both kinds of clocks. A pendulum clock is more of a “macro-sized” object and its bob tends to obey the “macro-sized” laws of Newtonian mechanics. But an atom is micro-sized and, internally, works under slightly different laws. This is because there are tiny little fields inside atoms, and the particles of the atoms have to deal with and react to these fields constantly. So, this is where the laws of “quantum mechanics” come into play. A pendulum bob doesn’t have to deal with the laws of quantum mechanics, since it is a large object that is made up of billions of atoms, and small weak electric and magnetic fields generally don’t affect its swing rate, whereas deep inside the bob, the small fields do affect the oscillation rates of the atoms that make up the bob.
For example, a hot bob will generally not change its swing rate, but the hot atoms will change their internal harmonic oscillation rates inside the bob. So, if we could put some kind of “atomic probe” into the bob, we would see that the “atomic clocks” (the atoms) inside the bob speed up their internal oscillation rates when the bob is hot, while the swing rate of the bob is not affected by the temperature.
It took a long time for me to learn that there are more kinds of “time” than just one, and that “time” is tied in different ways to different kinds of motion and vibration rates of physical matter.
If you were flying in a GPS satellite, all you, as a biological being, would notice is the lack of a gravitational “pull” on your body, and you would notice, from messages sent to you from earth, that earth-based atomic clocks are ticking a little more slowly than your GPS sat clock. But you would feel no difference in “time” since your satellite would be nice and warm inside, so your body temperature would not go below 98.6 degrees F. Your own biological time is based on thermodynamic time, not atomic time.
Your brain is designed to go unconscious if your body temperature drops by 5 to 10 degrees, so you would go unconscious before you began to notice any biological “time” rate difference as a result of the lowering of your brain temperature.
There is nothing amazing about atomic oscillation rate slow-downs and speed-ups. This is just a normal function of nature. All kinds of clocks slow down and speed up for a variety of physical reasons, but no single kind of clock rate change represents a total “time” rate change at that clock. This concept is an old misconception that is based on Newton’s old definition of “absolute time”. But an oscillating atom no more represents all of “absolute time”, any more than a pendulum clock or a mechanical balance-wheel clock does. These are different kinds of click that operate by different laws of physics, and they tick out and measure different types of time. Some can slow down while other speed up. Some physical parts of different kinds of clocks can change "time" or "aging rates" while other prarts of the same clock do not change rates.
HOLY SH*T!
Easy boy [woof], its not that bad, just take it slow. If you're really interested, pick up a laymans' book on the subject. You'll get it.
This is the part I was looking for: it is not correct. Yes, there are different ways of defining/measuring time, but there is one that affects all the others: relativistic time. The effects on atomic clocks are not simply mechanical clock rate effects they are manifestations of the rate of time passage itself changing.
No, that is not correct. That is a common myth that was probably started by Lorentz in his 1895 book, and it was continued by Einstein in his 1905 SR version of the 1895 Lorentz theory. It was Lorentz who invented time dilation, slow atomic clock “tick” rates, mass increase, two relatively moving “systems”, length contraction, the Lorentz Transformation, the S1 and S2 systems, and the speed limit of “c”, but Lorentz’s theory involved fields, acceleration, atomic clocks, and real forces of nature.
The idea that an “atomic clock” might be a “true time” clock can be traced back to Maxwell’s 1873 book and his definition of “time”, using an oscillating atom as an example of a perfect “clock”. When Lorentz, in the late 19th Century, theorized that atomic vibration rates would slow down under certain conditions, and when Einstein began to talk about time dilation, then it became common in the field of physics and astronomy to think of atomic time as “true” time. But, gradually, Einstein drifted away from that point of view, somewhat. However, “atomic time” became the time-base standard for physics, but thermodynamic time (“heat time”) gradually became the time-base standard for biology and other fields. Both are equally valid, but only for their particular kinds of time. On earth, and in fact in most of the universe, thermodynamic time usually overrides atomic time and is far more important and more representative of “true time” than atomic time is.
Where in the writings of Einstein and Lorenz do they specify that their theories apply only to atomic clocks?
See Lorentz’s 1895 “Versuch Einer Theorie Der Elektrischen Und Optischen Erscheinungen In Bewegten Körpen.” See page 38: “Nimmt man nun diese Vertheilung für das System S2 und leitet daraus durch die oben besprochen Transformation ein System S1 ab, so besteht auch in diesem ein Ueberschuss positiver Ionen nur an einer gewissen Oberfläche E, während in allen inneren Punkten die electrische Kraft x verschwindet.”
See his chapter titled, “Abschnitt III, UNTERSUCHUNG DER SCHWINGUNGEN, WELCHE VON OSCILLIRENDEN IONEN ERREGT WERDEN,” starting on page 48. This is where he introduced atomic time dilation in 1895.
You can find Einstein’s introduction of atomic clocks in his 1911 paper. That’s when he switched over from mechanical to specifically atomic clocks.
See also Charles Steinmetz’s “Four Lectures on Relativity and Space,” 1923, Dover 1967 Edition, page 67, where he explains Einstein’s use of atomic clocks. See also Maxwell’s 1873 definition of an atomic clock in Volume 1 of his “Treatise on Electricity and Magnetism”. Also See Einstein’s 1918 paper, “Dialog über Einwände gegen die Relativitätstheorie,” from Die Naturwissenschaften 6 (1918). In this paper, he adds atomic clocks, gravity fields, and acceleration to the 1905 SR theory, as the result of his 1911 discovery.
... The effects on atomic clocks are not simply mechanical clock rate effects they are manifestations of the rate of time passage itself changing. [/B]
Not so Russ; in dealing with relativistic time dilation effects we talk about clock RATES. There is no reference to the absolute nature of time being changed, only the clock 'rates'.
Nowhere is this more evident than in atomic clocks.
For ex., in cesium clocks, we 'define' one second as 9,192,931,770 oscillations of the cesium133 atom (hyperfine transition). When the clock is carried into a relativistic situation it is the the number of oscillations compared to a clock at rest that changes.
It says nothing about the absolute value of the passage of time.
Creator:smile:
hhmmmm interesting battle...
i wonder...
has anyone ever been able to actually DEFINE what time IS?
When we regard relativistic clock rates for a number of differences, we are only explaining the EFFECTS of time, not actually defining it. Oscillation rates are the EFFECTS of time.
We KNOW the effects of a car.
We also KNOW exactly what a car IS. Therefore we are able to manipulate the car as we choose.
If we could KNOW exactly what time IS, then maybe we could easily control it, or even move throughout it.
Nice, David - post your reply in German. Sorry, mine's a little rusty, but I don't see the words "cesium" or "rubidium" in there. Surely, the clock rate errors for different types of clocks must be different and the theory must specify which it applies to...
That is true, Creator, but the reason the rate of that clock changes is that time itself flows at a different rate.
David and Creator, I have no real interest in arguing this as it really isn't arguable. Modern scientists accept that Einstein's Relativity is discussing the rate of the passage of time itself. Much of our modern technology uses these theories and that is how the engineers use them. If you ask a GPS engineer, he will tell you that the reason GPS satellite clock rates are calibrated down from normal prior to launch is the combined effects of SR and GR on the rate of the passage of time for an object in orbit.
Certainly: http://dictionary.reference.com/search?q=time
A useful Google: http://www.google.com/search?as_q=g...s_occt=any&as_dt=i&as_sitesearch=&safe=images
By believing in different sorts of time (atomic, thermodynamic), you rejected the fundaments of GR and physics:
The Equivalence Principle
You go on a long trip to a near-by star taking the Rollex (read non atomic clock with you and also a atomic clock. Your spaceship, you will notice, has no windows (they had to cut the budget somewhere!), but you go anyway. You experience the effects of lift-off but after a while you appear to be at a standstill: you are then moving at a constant speed with respect to Earth. But remember we assumed that the Rollex still ticks the same way as the clocks on Earth, and sinds Einstein that the atomic clock does not. So you will see a mismatch between the Rollex and the atomic clock: this is an experiment which is done completely inside the spaceship and which determines whether you are moving. If there were such a Rollex the Principle of Relativity would be violated.
Free quoted from:
http://phyun5.ucr.edu/~wudka/Physics7/Notes_www/node78.html#SECTION03123000000000000000
A useful Google: GPS and Relativity
Wow, i had a good time reading the page about relativity and GPS! It stated that at the equator acceloration and gravity dilation cancel out each other. To my pleasure, I ironically concluded yesterday that this must be a possibility regarding a hypothetical "electrical pole" that was so tall it reached out far into space. I thought that maybe since the Gravity dilation would predict that time for the pole (relative to that of the Earth) would speed up as the pole reached farther, and Acceleration dilation would predict that time for the pole (relative to that of the Earth) would slow down, that the 2 differences in relative time for the pole might actually cancel out each other and time for the pole would relatively(to the surface of the Earth) be absolute.
Athough it started to confuse me when it stated that when a traveler left the Earth at 8/1994 at the speed of .99c headed for Alpha Centauri, the (GPS)time at Alpha Centauri upon the travelers arrival would be 9/1998, the natural time for the traveler would be an ellapsed 7 months, and the syncronized Earth watch(impossible throuth SR) would only have read an ellapsed 1 month! What the heck do they mean by "natural time" Wouldnt this be the same thing as the 1 month time? This doesn't make sense to me. Maybe I don't fully understand the way in which they present this, but I would assume that only 1 month (Earth time) would have passed for the traveler upon arrival at Alpha Centauri. Then it stated that upon return to Earth, the GPS time would be 10/2002! This even further confused me since it only took a relative (to Earth) 1 month to get back!
I fully understand the concept that if you travel at .99c for an extended time relative to Earth that upon your return to Earth you will actually be re-entering into the future time of Earth (relative to the elapsed time you experianced while out in space traveling at .99c). It may be hard to tell what my point is in the previouse paragraph, but maybe the confusion came from the way in which it was written on the site.
Maxwell mentioned “sodium” in his 1873 comments.
Originally posted by Peterdevis
the Rollex
I think a Rolex will probably tick a little faster in space, since there are no gravitational forces pulling down on its gears and their shafts, so they won’t experience as much friction in space. But the speed up will not match the same speed-up rate as an atomic clock, because the Rolex speed up is a large-scale “mechanical” function, while an atomic oscillation speed up operates by quantum mechanics rules.
Regarding a Rolex or any kind of balance-wheel watch or clock, think of it this way: Put the watch inside a rapidly spinning centrifuge, and notice that the higher the g forces, the more friction is placed on the bearings and the gear shafts. This will tend to slow the watch down a little. However, if you put an electronic watch in your refrigerator freezer, that will slow it down a little, for thermodynamic and quantum mechanics reasons. Put a pendulum clock high on a mountain and it will slow down. Put an atomic clock in a valley and it will slow down.
These different types of clocks will slow down and speed up for different reasons, because different laws of physics apply to the different types of clocks.
No clock slows down due to “relative motion” alone, since no physical force is placed on the mechanism of the clock. Different kinds of clocks will slow down and speed up if you add forces to them or take forces away from them.
Your biological time while you are traveling in space is determined by your molecular vibration rates. This is “thermodynamic” time.
If the SR theory were true, and if you traveled at .99c, your molecular vibration rate would slow down to near zero and you would freeze to death. SR theory just doesn’t work. You can’t have your clocks and your aging rate slow down, while your molecular vibration rates don’t change at all. If you remain warm during your trip, that means your molecular clocks, your molecular vibration rates are not slowing down.
Go read some Lorentz stuff. That’s what the SR theory was based on and modeled from, but unfortunately Einstein neglected to include acceleration, fields, and real physical forces, so the SR theory does not work in real life.
[Peterdevis]
...the natural time for the traveler would be an ellapsed 7 months, and the syncronized Earth watch(impossible throuth SR) would only have read an ellapsed 1 month! What the heck do they mean by "natural time" Wouldnt this be the same thing as the 1 month time? This doesn't make sense to me.
The specific link might help, but from the context given, "natural time" appears to be the time shown by your watch in your frame of reference.
So then which is the type of atomic clock that Einstein used in his books (did he always use the same kind?) and what are the transformation equations for converting time between different atomic clocks?
Analog watches have used frictionless springs for several hundred years and and since the spring is where the frequency comes from, they are not mechanically affected by gravity. If friction due to weight mattered, they'd tick at different rates upside down and right side up.
All laws of physics apply in all cases. The effects are only relevant in certain cases. But the law of physics for the last case is relevant to all of them.
Then explain GPS. The engineers who make GPS satellites use the predictions of SR (motion related time dilation) in the calibration of the satellites' clocks.
No. From your frame of reference if you shut your eyes, nothing has changed. You don't understand the relevance of frame of reference.
SR theory just doesn’t work...so the SR theory does not work in real life.
Scientists, engineers, and laypeople who don't even know it, use Einstein's Relativity every day in real life. It hasn't let them down yet. Maybe I was wrong in the other thread: the problem here appears to be you just plain don't understand it.
He called them “elementary light generators” in the 1911 theory. You need to read Maxwell’s book and Steinmetz’s book so you will know what he was talking about. You really need to read the original theories, the original books, and not get all your information out of mass-media popular books designed for junior high school kids. You need to also read the old major science books of that era, such as Maxwell’s work, which was still fresh and new when the original theories were developed in the late 19th and early 20th Century. That will give you more background information so you can understand the newer theories from the early 20th Century. For example, I’ve never seen a modern book that says exactly what Einstein meant by “elementary light generators”. However, I did find the information in Maxwell’s book and Steinmetz’s book from 1923.
All mechanical watches have shafts and bearings. That’s what a 23 jewel watch used to be. They used hard ruby or other jewels as the bearing pivot points, since the jewels were harder than metal and didn’t wear out as often. Gravity increases friction in the bearings of mechanical watches.
Read Lorentz’s theory and some of Dr. Su’s papers. They explain it. It has nothing to do with SR theory. The atoms in the clocks don’t know they are “moving relatively”. They only know they are “moving” if they feel some kind of motion-related force.
From your frame of reference if you shut your eyes, nothing has changed. You don't understand the relevance of frame of reference. Scientists, engineers, and laypeople who don't even know it, use Einstein's Relativity every day in real life. It hasn't let them down yet. Maybe I was wrong in the other thread: the problem here appears to be you just plain don't understand it.
Einstein tried to work thermodynamics into the SR theory in his 1907 paper, “On the Relativity Principle and the Conclusions Drawn From It,” but he got all mixed up. When he wrote the SR theory in 1905, he didn’t consider the thermodynamic implications.
See, if “all of time” slows down inside a “moving” frame, then the vibration rates of all the molecules slow down too, since they are, in effect, molecular clocks, and everything inside the frame freezes, based on the "time slowdown" rules of SR theory itself. He just didn’t think of that when he wrote the paper. I thought of it, and I finally tracked down his 1907 paper in which he tried to introduce thermodynamics into the SR theory. But it never worked out. His 1905 theory was based on his misunderstanding of the 1895 Lorentz book.
You really need to get a copy of his 1918 correction paper, in which he adds fields, acceleration, and atomic clocks to the SR theory. When he does that, then it becomes the 1895 Lorentz theory that he tried to copy in the first place. You need to get a copy of Lorentz’s book too, to see the original of the Lorentz Transformation and many of the ideas that were copied for the SR theory. Modern books won’t tell you this stuff. You’ve got to do your own research.
The Lorentz book is so rare, I saw a copy offered for sale in Holland for 6,750 Euros. That’s more than $6,750 dollars. Some day the book with be translated and published in English, and everyone will see where the SR theory originally came from, and how the 1905 errors occurred.
Here is a page from my copy of the 1895 Lorentz book:
http://im1.shutterfly.com/procserv/47b4dc32b3127cceb821b68ead3f0000001610
He introduced atomic time dilation on page 49, when Einstein was just 16 years old and still in high school.
  • · Replies 18 ·
  • · Replies 19 ·
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 36 ·
  • · Replies 37 ·
