Calculate Angular Momentum of 2kg Object at Time t
The discussion focuses on calculating the angular momentum of a 2kg object with the position vector r = -4t i + 3t^2 j (m). The correct angular momentum, derived using the formula L = r × p, where p is the momentum (mv), is determined to be -24t^2 k (kgm^2/s). The velocity vector v is calculated as v = -4 i + 6t j by differentiating the position vector r with respect to time. The final result incorporates the time variable t, confirming that the angular momentum is indeed a function of time.
  • Understanding of angular momentum and its formula L = r × p
  • Knowledge of vector differentiation and calculus
  • Familiarity with momentum concepts, specifically p = mv
  • Basic understanding of vector notation in physics
  • Study vector calculus to enhance differentiation skills in physics contexts
  • Learn about cross products and their applications in physics
  • Explore angular momentum in different coordinate systems
  • Investigate time-dependent motion in classical mechanics
Students and professionals in physics, particularly those focusing on classical mechanics, as well as educators teaching angular momentum concepts.
vu10758
A 2kg object has a position vector r = -4t i + 3t^2 j (m). Find its angular momentum relative to the origin as a function of time.
The correct answer is -24t^2 k (kgm^2/s).
I know that L = r*p and p is mv
so I differentiate r to get v
v = -4 i + 6t j
do I just multiply 2 and the cross proudct of r and v? I don't know what to do because of the t in the equation for vector r.
v = -4 i + 6t j
Just do it. The angular momentum is to be found as a function of time. t will be in the result
  • · Replies 17 ·
18K
