Two Falling Stones and Their Center of Mass
The discussion focuses on calculating the center of mass (COM) of two stones dropped from the same height at different times. The first stone is dropped at t = 0, while the second stone, with twice the mass, is dropped at t = 250 ms. At t = 600 ms, the correct position of the COM is determined by evaluating the positions of both stones at that time, leading to the conclusion that the COM is at 0.012 meters below the release point. The velocity of the COM is derived from the position calculations, emphasizing the importance of using the correct initial conditions and equations of motion.
  • Understanding of kinematics, specifically equations of motion under constant acceleration
  • Familiarity with the concept of center of mass in physics
  • Knowledge of gravitational acceleration (9.81 m/s²)
  • Ability to perform basic calculus for deriving velocity from position
  • Review kinematic equations for motion under gravity
  • Study the concept of center of mass in multi-body systems
  • Learn how to derive velocity from position functions using calculus
  • Explore problems involving multiple objects in free fall to solidify understanding
Students and educators in physics, particularly those focusing on mechanics and kinematics, as well as anyone interested in understanding the dynamics of multiple objects in motion.
mbrmbrg
A stone is dropped at t = 0. A second stone, with twice the mass of the first, is dropped from the same point at t = 250 ms.
(a) How far below the release point is the center of mass of the two stones at t = 600 ms? (Neither stone has yet reached the ground.)
(b) How fast is the center of mass of the two-stone system moving at that time?
First and foremost: the times are 0.250s and 0.600s respectively.
I set my co-ordinate system with x=0 at the release point and the x-axis is positive in the downward direction (sorry).
Other than that...
I first found (or perhaps tried to find) the center of mass at 0.250s and said that the COM moves with a constant acceleration of 9.81m/s^2.
PART A:
To find where the first stone was at 0.250 s, I used the equation [tex]x=x_0+v_0t+\frac{1}{2}at^2[/tex], where x_0 and v_0 are both 0. so x = 1/2g(.250s)^2 = 0.307m.
I then said that at 0.250s, [tex]x_{COM}=\frac{(2m)(0)+(m)(0.307)}{m+2m}=0.012meters[/tex]
So at 0.600s, the position of the COM is given by [tex]x=x_0+v_0t+\frac{1}{2}at^2[/tex]. I solved that saying using 0.012m as the initial position and 0m/s as the initial velociy, and got an incorrect answer (1.87m)
PART B:
Not surprisingly, when I used my answer for part (a) in the equation [tex]v^2=v_0^2+2a\Delta x[/tex], I also got the wrong anwer.
And now I am stuck (and feeling stupid, because this problem got one out of three dots for difficulty).
For part A, you should simply find where the 2 stones are at .6 sec, and find their center of mass.
Thanks, that got the right answer for part a.
For part b, I wrote the equation for the position COM purely symbolically then took the first derivative and used that to find velocity. So that's that!
  • · Replies 25 ·
