Thread Closed
gravitational force magnitude problem
Share Thread Thread Tools
Nov22-06, 01:32 PM   #1
Question
What is the magnitude of the net gravitational force on the 20.0 kg mass?
What is the direction of the net gravitational force on the 20.0 kg mass?
What is the magnitude of the net gravitational force on the 5.0 kg mass?
I'm completely lost on this.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov22-06, 01:40 PM   #2
Mentor
Each pair of masses exerts equal and opposite gravitational forces on each other according to Newton's law of gravity. (Look it up if you have to.) Calculate all the forces acting on each mass and just add them up, remembering that forces are vectors.
Nov22-06, 01:49 PM   #3
so would the gravity be assumed to be 9.8 m/s?
Nov22-06, 01:55 PM   #4
Mentor
Quote by mawalker View Post
No. 9.8 m/s^2 is the acceleration due to Earth gravity near the Earth's surface. I assume in this problem you are to calculate the gravitional forces between these objects, ignoring any other gravitating bodies (such as the Earth). Pretend they are in outer space and use Newton's law of universal gravity.
Nov22-06, 03:20 PM   #5
i'm still not getting it. for the force on the 20 kg unit i have 6.67*10^-11*(20)*(10)/(.2)^2 + 6.67*10^-11*(20)*(5)/(.1)^2 giving me a net total force of 3.04 * 10^-4, which is incorrect
Nov22-06, 03:29 PM   #6
Mentor
The force from the 10 kg mass points in +y direction while the force from the 5 kg mass points in the +x direction. Add them like vectors, not numbers.
Nov22-06, 03:50 PM   #7
i've never really understood vector addition all that much. do i just square both numbers and add them together, then take the square root?
Nov22-06, 04:02 PM   #8
Mentor
That will work, since those vectors are perpendicular.
Nov22-06, 04:17 PM   #9
how do i go about finding out which direction the net gravitational force on the 20kg object is? i know it would be somewhere in between the two but i don't know how to figure out how many degrees it is.
Nov22-06, 07:06 PM   #10
Mentor
Given the y component and x component of a vector, the angle it makes with the x axis can be found using:
[tex]\tan\theta = \mbox{y-component}/\mbox{x-component}[/tex]
Dec10-08, 10:31 PM   #11
I used Force in y= [G (10)(5) / r^2 ] sin theta =5.96 x 10 ^-8
r = 0.223606 sin theta = 0.2/ 0.223606 =
Force in x = [G (5)(20)/ (0.1)^2] = 6.67 x 10^-7
magnitude = sq root of (force in y) ^2 + (force in x) ^2 = 6.6966x 10^-7?
is an angle in cos or sin?
Thread Closed
Thread Tools
Similar Threads for: gravitational force magnitude problem
Thread Forum Replies
magnitude of an electric force problem with vectors Introductory Physics Homework 3
Gravitational Force Problem Introductory Physics Homework 1
Magnitude and Direction, Gravitational force Q Introductory Physics Homework 2
Force and Magnitude Problem Introductory Physics Homework 25
Help Please: Gravitational Force Problem Introductory Physics Homework 1
