How Close is a Copper Bar to Breaking Under High Tensile Stress and Sound Waves?
The tensile stress in a thick copper bar reaches 99.5% of its elastic breaking point, quantified at 13.0 x 1010 N/m2. To determine the displacement amplitude that will cause the bar to break, the maximum pressure change is calculated as ΔP = 6.5 x 108 N/m2. The maximum particle speed at this breaking point can be derived using the formula vmax = ωA, where ω is the angular frequency related to the 500 Hz sound wave. The bulk modulus (B) is essential for calculating wave speed, expressed as v = √(B/ρ).
  • Understanding of tensile stress and elastic breaking points
  • Knowledge of sound wave properties, specifically frequency and amplitude
  • Familiarity with the equations of motion for waves, including vmax = ωA
  • Basic principles of material science, particularly bulk modulus (B) and density (ρ)
  • Calculate the displacement amplitude required for a copper bar to break under tensile stress
  • Explore the relationship between frequency and wave properties in solid materials
  • Investigate the concept of bulk modulus and its application in material stress analysis
  • Learn about the effects of sound waves on different materials under varying stress conditions
Material scientists, mechanical engineers, and physicists interested in the mechanical properties of metals and the effects of sound waves on structural integrity.
lizzyb
The tensile stress in a thick copper bar is 99.5% of its elastic breaking point of 13.0 X 10^10 N/m^2. A 500 Hz sound wave is transmitted through the material. (a) What displacement amplitude will cause the bar to break? (b) What is the maximum speed of the particle at this moment?
Comments:
(b) is easy because one we know the maximum displacement (or amplitude), we may use [tex]v_{max} = \omega A[/tex]
For (a), though, it seems like the frequency isn't related to this part of the question. If the copper is stretched so far, beyond it's elastic breaking point, then it will break, but how do I determine this? Thank you.
Well, we know that [tex]\Delta P = 13.0 \times 10^{10} - .995 \times 13.0 \times 10^{10} = 6.5 \times 10^8[/tex]
and we can assume that this is [tex]\Delta P_{max}[/tex] and we may use the equation [tex]\Delta P_{max} = \rho v \omega s_{max}[/tex] where rho and omega are easily determined.
What about v? The book says [tex]v = \sqrt{\frac{B}{\rho}}[/tex] so how would I determine B?
B is the bulk's modulus
9K
  • · Replies 20 ·
14K
  • · Replies 0 ·
11K
