A few problems for math league
  • Context: High School
  • Thread starter Thread starter BluE
The discussion revolves around several mathematical problems presented for a math league, focusing on integer solutions, properties of triangles, and polynomial equations. Participants explore various approaches to solve these problems, share insights, and challenge each other's reasoning.
  • Homework-related
  • One participant suggests that since 2003 and 2004 are coprime, any prime factor of 2003 must divide y, leading to a discussion on finding the least possible value of x.
  • Another participant questions the definition of "integral triangle," asking for clarification on whether it refers to the perimeter or area.
  • There is a claim that the equation (a^2 - b^2)x^2 - (a^2 + b^2)x + ab = 0 relates to the third problem, with some participants suggesting it resembles a trinomial squared.
  • One participant states that the greatest common divisor of two integers that differ by one is always one, implying that the solution should be straightforward.
  • Another participant provides a method to derive the roots of a polynomial and relates it to finding the sum of the squares of the roots.
  • Some participants express uncertainty about the first two problems while showing confidence in understanding the third problem.
  • There is a debate over the validity of different approaches to the first problem, with one participant defending a solution that does not explicitly mention the coprimality of 2003 and 2004.
  • Another participant argues that both reduced and unreduced forms of fractions are valid, leading to a discussion about clarity in mathematical communication.
Participants do not reach a consensus on the best approach to the problems, particularly regarding the first problem and the interpretation of the integral triangle. There are competing views on the sufficiency of the presented solutions and the clarity of explanations.
Some participants note potential misprints in the original problems and express concerns about the clarity of definitions, particularly regarding the term "integral triangle." There are also unresolved questions about the completeness of the solutions provided.
Students preparing for math competitions, educators looking for problem-solving strategies, and individuals interested in mathematical reasoning and discussion.
BluE
Let's see... I couldn't find the answers to these. They look fun- maybe you can find the solutions.
1.) If x and y are positive integers, and 2003x=2004y, what is the least possible value of x?
2.) An integral triangle is a triangle with positive side-lengths and a positive area. Such a triangle can have a perimeter as small as 3. What is the next smallest possible perimeter of an integral triange?
Mathematics news on Phys.org
Okay, here's a third one. I have to put it in separate pieces because it keeps sticking together in one line.
3.) [tex]a^2 - b^2 \neq 0[/tex]
[itex](a^2 - b^2)x^2 - (a^2 + b^2)x + ab = 0[/itex]
What are all real solutions of a for which the sum of the squares of the roots of [tex]x^2 - 8ax + 14a^2 = 0[/tex] is 25?
(This is the last piece.)
for the first one, as 2003 and 2004 differ by one, they are coprime. Here meaning, any prime factor of 2003 must divide y. you can put the rest together from there.
second, one find an equation for area using only side length (there is incidentally a misprint in your question, the word integer is missing from some sentence).
are all those posts to do with the third alone?
hint. x^2+px+q = (x-r)(x-s)
so find p and w in terms of r and s.
note u^2+v^2 = (u+v)^2 - 2uv.
that should let you solve the last one.
Well, I'm not sure about the first and second, but I think I understand the third one. It looks like a trinomial squared.
1. The greatest common divisor of two integers that differ by one is always one. This means that there can be no possible cancelling of factors between 2003 and 2004, which should make the only solution pretty obvious.
2. You haven't even described what is the integer in the integral triangle? Is it the perimeter or the area or something else. ?
3. What has "b" got to do with anything in this problem? Using only the last equation by itself you can show that a equals plus or minus 5/6
nothing to do with trinomials.
let's derive uart's answer:
let r and s be the roots of
x^x-8ax+14a^2 =0
mutliplying out (x-r)(x-s) we see that
-r-s = -8a
rs = 14a^2
we want r^2+s^2 = 25
using the identity I gave before
25 = 64a^2 - 28a^2= 36a^2
hence a = +/- 5/6
so, as uart mentioned, where's b gone?
1. 2003
2. 5
Wait-
2003x=2004y
x=2004y/2003
x/y=2004/2003
so x=2004 and y=2003?
That makes sense...
that alone doesn't tell you that 2003,2004 are the least possible. the answer has been given in a form that does tell you that, both by me and by at least one other person.
example find the least positive x and y such that 12x=18y.
12/18=y/x does not say y=12 x=18, rememebr you need the minimal solution.
it's rather obvious there how to find the minimal, so say what's going on in the larger example.
12x=18y
y/x=12/18=2/3
y=2, x=3
12*3=36=18*2
2003x=2004y
y/x=2003/2004=2003/2004 (no common factors)
y = 2003, x = 2004
2003*2004=2003*2004
Seems to amount to the same thing as the "better" answers to me.
cookiemonster
Originally posted by cookiemonster
12x=18y
y/x=12/18=2/3
y=2, x=3
12*3=36=18*2
2003x=2004y
y = 2003, x = 2004
2003*2004=2003*2004
cookiemonster
at what point in the answer given by Blue does he cite that 2003 and 2004 have no common factor? That is exactly what the 'better' suggestions were stating, and they were 'better' in the sense that they were correct.
The last time I left a fraction in unreduced form was grade school.
The nature of reducing the fraction is to compare the factors of two numbers, which is also the nature of the problem.
All I'm saying is that you can say that 2003 and 2004 are coprime because they differ by 1 and therefore don't have any common factors, or you can factor both 2003 and 2004 and demonstrate that 2003/2004 is reduced. It's the same thing and so both solutions are perfectly valid, so it's unfair to call BluE's solution inferior.
Personally, I rather prefer his solution.
cookiemonster
if you prefer reduced fractions, then I'll restate the question: where does blue state that the terms are in reduced form?
It is the standard 'write more words' thing that you get fed up with saying.
If Blue had mentioned *any* of those things about lowest terms reduced or coprime then it's fine, but as it stands there is one last step. Just because you've never left a fraction in unreduced form since grade school (which is when?) doesn't mean we assume everyone does this. In particular the answer doesn't demonstrate that Blue now knows why this is the correct answer.
Alright, I see now that it is in the fraction is reduced to the simplest form.
BluE -- your math teacher should be giving you the answers plus the explanations along with your test sheet in the days after each Math League (or at least that's what happens at my school)
  • · Replies 20 ·
  • · Replies 30 ·
