Equilibrium temperature of ice, water, and iron cup
The discussion focuses on calculating the equilibrium temperature of a system consisting of an ice cube, water, and an iron cup. The participants detail the heat transfer calculations involved, including the heat lost by water cooling from 40.0 °C to 0.0 °C, which amounts to 18418.4 J, and the heat required to melt the ice, calculated as 13735 J. The final equilibrium temperature is derived from the heat exchanges among the three components, with the formula Q(ice) = Q(cup) + Q(water) being central to the calculations. The correct approach involves setting up the heat balance equation accurately to find the final temperature.
  • Understanding of heat transfer principles
  • Knowledge of specific heat capacity
  • Familiarity with phase change concepts, specifically latent heat of fusion
  • Basic algebra for solving equations
  • Review the principles of thermodynamics, focusing on heat transfer and equilibrium
  • Study the specific heat capacities of water and iron
  • Learn about latent heat calculations, particularly for melting ice
  • Practice solving heat balance equations in multi-component systems
This discussion is beneficial for physics students, educators, and anyone interested in thermodynamics, particularly in understanding heat transfer in mixed systems involving different states of matter.
physgirl
so there're:
0.041 kg ice cube at 0.0 *C
0.110 kg water at 40.0 *C
in
0.062 kg iron cup at 40.0 *C
Find the equilibrium temperature of the cup and its contents:
So what I tried doing was... I found the heat lost by water if cooled to 0 *C, which was 18418.4 J (mass of water * water specific heat * temperature difference which is 40)
then found th eheat needed to melt ice, which was 13735 J (mass of ice * Lf)
then found the difference of the two to find the amount of heat left... and used that much heat to warm 0.151 kg of water (mass of initial water + initial ice) at 0 *C to its final temperature... so I did, delta T=Q/(mc) which gave T=7.4 *C...
so then I used that temperature in kelvin, which is 280.6 K and did:
(specific heat of water)(mass of water which is now 0.151)(280.6+T)=(specific heat of iron)(mass of cup)(313-T)
and solved for T... where did I make the mistake because this answer's not correct?
i think you can assume the equilibrium temperature is T , the three objects will reach this temperature after they are in eaulibrium
and the heat will be released from cup and water which in turn melt the ice so Q(ice get) = Q(cup release)+ Q(water relesase)
Q= CM(T-t) Plut every value in the equation
you will find out the final T
try and see whether it is right
  • · Replies 17 ·
10K
