How Far Does a Bus Travel After Accelerating and Decelerating?
  • Thread starter Thread starter exemplarysam
    Bus Travel
The bus accelerates at 1.5 m/s² from rest for 12 seconds, covering a distance of 108 meters. It then travels at a constant velocity for 25 seconds, adding 300 meters to the total distance. Finally, it decelerates at -1.5 m/s² until it stops, traveling an additional 150 meters. The total distance traveled by the bus is 558 meters, resulting in an average velocity of 9 m/s over the total time of 62 seconds.
  • Understanding of kinematic equations
  • Familiarity with acceleration and deceleration concepts
  • Basic knowledge of distance, velocity, and time relationships
  • Ability to perform algebraic isolation and substitution
  • Study the kinematic equation d = ut + 1/2at² in depth
  • Learn about constant velocity motion and its implications
  • Explore the effects of negative acceleration on motion
  • Investigate average velocity calculations in different scenarios
Students studying physics, educators teaching kinematics, and anyone interested in understanding motion dynamics in real-world scenarios.
exemplarysam
there is this problem that i really need help on
<b>a bus accelerates at 1.5m/s(squared) from rest for 12s. Itthen travels at constant velocity for 25s, after which it slows to a stop with an acceleration of -1.5m/s(squared).
(a) How far does the bus travel?
(b) What is its average velocity?
i won't give it away completely, but you'll be needing these equations [not in that particular order]
d = v\t
a = (v' - v) / t
d = [(v' - v)/2]t
v'^2 = v^2 + 2ad
isolation and substition will be involved :)
</b>
(a) To find the distance traveled by the bus, we can use the formula d= ut + 1/2at^2, where d is the distance, u is the initial velocity, a is the acceleration, and t is the time. In this case, the initial velocity is 0 m/s, the acceleration is 1.5m/s(squared) and the time is 12s. Plugging these values into the formula, we get d= (0)(12) + 1/2(1.5)(12)^2 = 108m. Therefore, the bus travels 108 meters in the first 12 seconds.
Next, the bus travels at a constant velocity for 25 seconds, which means its acceleration is 0 m/s(squared). Using the formula d= ut + 1/2at^2, where a= 0, we get d= (12)(25) + 1/2(0)(25)^2 = 300m. Therefore, the bus travels an additional 300 meters in the next 25 seconds.
Finally, the bus slows down with an acceleration of -1.5m/s(squared) until it comes to a stop. Using the same formula, d= ut + 1/2at^2, where a= -1.5, we get d= (12)(25) + 1/2(-1.5)(25)^2 = 150m. Therefore, the bus travels an additional 150 meters before coming to a stop.
The total distance traveled by the bus is 108 + 300 + 150 = 558 meters.
(b) To find the average velocity of the bus, we can use the formula v= d/t, where v is the average velocity, d is the distance traveled and t is the total time taken. In this case, the total time taken is 12 + 25 + 25 = 62 seconds. Substituting the values, we get v= 558/62 = 9 m/s. Therefore, the average velocity of the bus is 9 meters per second.
  • · Replies 20 ·
