| Thread Closed |
Question on Electric Motors? |
Share Thread | Thread Tools |
| Nov27-06, 01:30 PM | #1 |
I am trying to implement an electric motor as a generator at the end of a steering wheel shaft. The motor would be used to apply a resistance torque to the shaft. What type of motor would you recommend?
| Nov27-06, 06:21 PM | #2 |
This sounds like a rather odd project. Is the purpose of the motor specifically to generate electricity, or to dampen the motion of the shaft, or what?
| Nov28-06, 09:03 AM | #3 |
the purpose of the motor is to apply a small resistance (4-7 N*m) to the steering wheel shaft. The shaft itself will be turned by a steering wheel. this should allow the motor to run as a generator creating a voltage.
| Nov28-06, 10:31 AM | #4 |
Recognitions:
Why not use friction? Wrap the shaft with a piece of leather and put a clamp around the whole thing...
| Nov28-06, 01:22 PM | #5 |
sorry, i should have said this before, but the resistance needs to be able to vary from no resistance to around 7 N*m
| Nov28-06, 02:02 PM | #6 |
Recognitions:
tighten the clamp to vary the torque...
Seriously, a generator is complicated. Doesn't the torque depend on the speed? Also athe armature poles in a generator will give you funky results if you turn your steering wheel only a little (like 30 degrees). Mechanical systems are easy. Look at the simple brake on an exercise bike--you turn a screw that squeezes two pads onto the turning wheel. The knob has a pointer that indicates the relative drag. Once you calibrate the torque or drag (which you'd have to do your way too), you're done. |
| Nov28-06, 03:20 PM | #7 |
And if you have to have something that varies on the fly, without manual input, you might look into using the motor as a motor, instead of a generator. Check into how force-feedback joysticks work.
| Nov28-06, 09:58 PM | #8 |
A generator wouldn't be that hard to do. You would just use an MCU controlled digital potentiometer to apply resistance to the motor windings. Then it is just a matter of measuring the change in voltage to determine speed. Make sure you have a set of diodes in place at least equal to the sample rate of you MCU to prevent any damage in case Vin Diesel gets in your car.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Question on Electric Motors?
| Electric motors as muscles? | Mechanical Engineering | 12 | ||
| Best practice for large electric motors | Electrical Engineering | 3 | ||
| Electric Motors/Generators | Introductory Physics Homework | 3 | ||
| Electric Motors | Electrical Engineering | 3 | ||
| Electric Motors - Which way the force goes. | Introductory Physics Homework | 9 | ||
