Solve Tricky Problem for Curve y=(ax-b)/(1-x^2)-SOLVED by courtrigrad"
  • Thread starter Thread starter me_maths
The problem of determining the values of 'a' and 'b' in the curve equation y = (ax - b) / (1 - x^2) has been solved definitively. The curve must pass through the point (-2, 1) and have a tangent slope of 1 at that point. By deriving the equation and setting up a system of equations, it was established that both 'a' and 'b' equal 1. The key equations used were -2a - b = -3 and 5a + 4b = 9.
  • Understanding of calculus, specifically derivatives
  • Familiarity with curve equations and tangent lines
  • Ability to solve systems of linear equations
  • Knowledge of algebraic manipulation
  • Study the application of derivatives in curve analysis
  • Learn how to derive equations for tangent lines
  • Explore systems of equations and methods for solving them
  • Investigate the implications of curve behavior in calculus
Students and professionals in mathematics, particularly those focused on calculus, algebra, and curve analysis. This discussion is beneficial for anyone looking to deepen their understanding of derivatives and their applications in solving real-world problems.
me_maths
tricky problem please HELP :( -SOLVED by "courtrigrad"-
[SOLVED, thanks to "courtrigrad"!]
I've tried to solve this problem for over 3 or 4 hours but I can't figure out how, please help me.
Ok so it's a curve ( parable? ) y = (ax - b) / ( 1 - x^2 )
You are supposed to solve what 'a' and 'b' should be if the curve goes through the point (-2,1) AND that the tangents* direction of that same point (-2,1) is 45 degrees ( so the tangents 'k' value should be 1, which is 45 degrees ).
*I'm not sure but I might have the wrong name in English for 'tangent', but it is a line with the same 'k' value as the single point in the curve... if you know what I mean?
THE BELOW IS WHAT I'VE TRIED TO DO:
Ok, so we all know that to get the 'k' value of a point in a curve you must begin with taking the derivate of the curve, which in this case would be:
MAOL s.43 : D f/g = ( gDf - fDg ) / ( g^2 )
#1. y' = ( ( 1-x^2 )*a - ( ax-b )*( 2x ) ) / ( 1 - x^4 )
and then you should put the derivate in a function of the x value, something like: y'(x) = ... , which would in this case be: y'(-2) = ... .
so we take that y'(-2) = ... and equal it to 1, because that's the 'k' value we had to have for that point.
and thus we should get an equation with both 2 unknown variables, 'a' and 'b' , in which we should somehow figure out what they should be to get this to work... which is where I fail.
The answer for this problem is that 'a' and 'b' both = 1.
I've tried to do the countings myself etc but I can't come up with it...
Could someone please help me!?
You know that [tex]1 = \frac{-2a-b}{-3} \Rightarrow -2a-b = -3[/tex]Also [tex]y'(x) = \frac{(1-x^{2})(a)-(ax-b)(-2x)}{(1-x^{2})^{2}}[/tex]Thus [tex]y'(-2) = 1 = \frac{-3a+8a+4b}{9} \Rightarrow 5a + 4b = 9[/tex]
So the two equations are: [tex]-2a - b = -3[/tex] and [tex]5a+4b = 9[/tex]
Solve these two equations for [tex]a,b[/tex] and you should get the answer.
Aah!
Thanks a lot!
Forgot completaly that you could use the first equation to compare it to the result of y'(-2) = ... . Not to mention that I made a few mistakes in the calculating also such as (1-x^2) would be (1-x^4) which is totally wrong...
Thanks again, helped me tremendously! <3 <3
