Calculating Acceleration and Friction in Rolling Motion Without Slipping
The discussion focuses on calculating the acceleration, friction force, and minimum coefficient of friction for a hollow spherical shell with a mass of 2 kg rolling down a 38-degree incline without slipping. Key equations include the relationship between linear and angular velocities, V(center of mass) = Rω, and the kinetic energy equation K = 1/2Mv² + 1/2Iω², where I represents the moment of inertia. The participants confirm that assuming a radius R is essential for solving the problem, as it will cancel out in the final calculations.
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with the equations of motion for rolling objects
  • Knowledge of kinetic energy equations
  • Basic trigonometry for resolving forces on an incline
  • Study the concept of moment of inertia for different shapes, particularly hollow spheres
  • Learn how to derive the equations of motion for rolling without slipping
  • Explore the relationship between linear and angular velocities in rolling motion
  • Investigate frictional forces and their role in rolling dynamics
Physics students, mechanical engineers, and anyone studying dynamics of rolling motion will benefit from this discussion.
Pawprint29
I can't figure out this problem. Pretty much totally lost. It has a hollow, spherical shell with a mass of 2kg, rolls without slipping down an incline of 38 degree's. It wants me to find the acceleration, the friction force, ane the minimum coeffcient of friction needed to prevent slipping.
The examples in my book and the equations all seem to have the Radius in them, and my problem doesn't give a radius. The equation that is has is Vcm=Rw.
So I'm not sure what to do when I don't have the radius and only the mass.
Since is says it is a hollow sphere, am I supposed to do something with the motion of inertia ? With K=1/2Mv^2+1/2Iw^2 ?
And then I don't know how I'm supposed to find the frictional force and the coeffcient of friction. g(sinθ-μcosθ)=a ?
It helps if you use the homework posting template that is provided. Please use it next time.
Yes, you need to use the moment of intertia. The friction force supplies the rotational energy for the cylinder. The cylinder will acquire both translational and rotational energy, as the equation you've written indicates.
Just assume the radius is R to get started. You are right, the linear and rotation velocities are linked by V(center of mass) = R.omega.
R will appear in other places as well (e.g. the moment of inertia). With luck, all the R's will cancel out in the end.
  • · Replies 42 ·
  • · Replies 21 ·
  • · Replies 60 ·
  • · Replies 35 ·
  • · Replies 18 ·
  • · Replies 17 ·
