Speed of spacecraft (gravitational force)
An unmanned spacecraft in a circular orbit around the Moon at an altitude of 43.0 km experienced a speed reduction of 20.0 m/s due to an electrical fault. To determine the crash speed upon impact with the lunar surface, the gravitational constant (6.673 x 10^-11 m²/kg²), the mass of the Moon (7.35 x 10^22 kg), and the Moon's radius (1.74 x 10^6 m) were utilized. The final speed calculation involves balancing centripetal and centrifugal forces, leading to the conclusion that the spacecraft will crash at a significantly increased speed if no corrective measures are taken.
  • Understanding of gravitational force and its calculations
  • Familiarity with centripetal and centrifugal forces
  • Knowledge of kinetic energy concepts
  • Proficiency in using the equation v = sqrt(G * m_e / r)
  • Study the application of gravitational constants in orbital mechanics
  • Learn about the relationship between centripetal force and orbital speed
  • Explore energy conservation principles in orbital dynamics
  • Investigate corrective measures for spacecraft trajectory adjustments
Aerospace engineers, physicists, and students studying orbital mechanics will benefit from this discussion, particularly those interested in spacecraft dynamics and gravitational effects on motion.
whitetiger
An unmanned spacecraft is in a circular orbit around the moon, observing the lunar surface from an altitude of 43.0 km (see Appendix F). To the dismay of scientists on earth, an electrical fault causes an on-board thruster to fire, decreasing the speed of the spacecraft by 20.0 m/s.
If nothing is done to correct its orbit, with what speed (in km/h) will the spacecraft crash into the lunar surface?
Take the gravitational constant to be 6.673 x 10^-11\cdot {\rm m}^{2}/{\rm kg}^{2}, the mass of the Moon to be 7.35 x 10^22\:{\rm kg}, and the radius of the Moon to be 1.74 x 10^{6}\:{\rm m}.
We can use equation v = sqrt(Gme)/r))
Show some work or some reasoning or something that tells us you gave it some thought. Then we can advice you where you may be misunderstanding something.
Thank you KoGs for replying to my question. I have finally figure our how to solve the problem. First I have to balance the centripetal force and the centrifugal forces.
After finding the initial kinetic energy and the energy due to falling I was able to find the speed at which it hits the planet
Again thank for your help
9K
