Designing a High-Heat Flux Test Rig for Intel Processors
  • Thread starter Thread starter Cyrus
    Processor Test
The discussion centers on the design of a high-heat flux test rig for Intel processors, specifically targeting heat removal technologies capable of dissipating up to 2000 W/cm2 from a 1 cm x 1 cm area. The project emphasizes the necessity of liquid cooling solutions, including single-phase liquid cooling in microchannels, immersion flow boiling, and jet impingement cooling. Key considerations for the design include temperature limits, measurement accuracy, and cost, with a focus on using readily available materials. The project report must detail design considerations, dimensions, and heat transfer performance.
  • Understanding of heat transfer principles and thermal management
  • Familiarity with liquid cooling technologies
  • Knowledge of thermocouple usage for temperature measurement
  • Experience in project design and engineering documentation
  • Research advanced liquid cooling techniques such as immersion flow boiling
  • Study heat transfer coefficient calculations for high-heat flux applications
  • Explore the design and application of cartridge heaters in thermal testing
  • Investigate cost-effective materials suitable for high-performance thermal applications
Mechanical engineers, thermal management specialists, and students involved in heat transfer projects will benefit from this discussion, particularly those focusing on high-performance cooling solutions for electronic systems.
Cyrus
Every semester, at least one of my classes involves a project. For Mechanics of Materials, we made a beam, performed an analysis and tested in a universal bending machine. For Thermodynamics, we had to design a HVAC system that provided Heating/Air Conditioning, dehumidification, a cool water supply, and power using microturbines. For Fluids, we had to make a working model of a Urinary System and perform an analysis on the flowrates and use the non-dimensional correlations to scale the findings back down to a human size bladder. This semester, we had to make a test rig for an Intel Chip. Here is the project statement:
ENME 332: Heat Transfer Design Project Fall 2006
Future electronic systems and power electronics will require increasing use of high-heat flux removal technologies-see the attached NY Times article on the thermal problems facing electronics. High heat flux thermal designs are necessary to maintain lower operating temperatures, which increases the reliability of components and can result in higher performance. Use of liquid cooling will become unavoidable as the power dissipation levels increases in future electronic systems. Possible liquid cooling technologies include singlephase liquid cooling in microchannels, immersion flow boiling, spray cooling, jet impingement cooling, thermosyphons, and heat pipes. We wish to build a test rig to measure the heat removal capability of various cooling technologies such as sprays and jets. It is your job to design a heater that can remove heat fluxes up to 2000 W/cm2 from a 1 cm x 1 cm area. The fluid striking the surface is at a temperature of 20°C, and the heat transfer coefficients can be up to 400,000 W/m2-K. One design that has been used in the past to test much lower heat fluxes is shown on Figure 1. One or more cartridge heaters are placed into a block of copper, and the heat flux is determined from the temperature gradient in the region below the cooled surface measured using thermocouples spaced a known distance apart. Some aspects you should consider in your design are 1). temperature limits, 2).accuracy of your heat flux measurements and instrumentation, 3). Cost. Your design should use readily available parts (i.e., no materials like “unobtainium”). Please submit a report describing your design (5 pages max., single spaced, 1” margins, Times New Roman) including designs considered, dimensions, heat transfer performance, measurement accuracy, a list of materials, and cost. You may work in groups of up to three—you should choose your groupmates from your section. The project is due Wednesday, Nov. 29th in lecture.
The hardest part about this project was that it was completely open. Anything goes, so long as you can provide up to 2000W of power. As my professor said, it's deceptively simple at first sight.
I'm actually quite interested in this and the links don't work...
"File not found
The link you have clicked is not available.
Use only the link that was generated by YouSendIt and emailed to the recipient(s)."
  • · Replies 67 ·
