Solve Rigid Body Motion: Pendulum Rod & Disk Eqns of Motion
The problem involves a pendulum system consisting of a uniform rod and a uniform disk, where the rod is fixed at one end and the disk is attached to the rod's free end. The objective is to derive the Lagrangian and equations of motion for this system.
  • Mixed
  • Participants discuss dividing the problem into two parts for the rod and the disk, considering their respective kinetic and potential energies. There are questions about the correct treatment of the disk's moment of inertia and whether to include translational motion in the kinetic energy expressions.
Several participants have provided insights into the setup and dynamics of the system, with some suggesting the use of the parallel axis theorem for the disk's moment of inertia. There is an ongoing exploration of how to accurately express the kinetic energies and equations of motion, with no clear consensus yet on the final forms.
Participants are navigating the complexities of rigid body motion and the implications of using different reference points for moment of inertia. There are also considerations regarding the separation of translational and rotational kinetic energy components.
Logarythmic
Problem statement:
Consider a pendulum consisting of two parts: a uniform rod of mass m, length l, negligible thickness and with one end fixed; and a uniform disk of mass [tex]\mu[/tex] and radius [tex]\rho[/tex].
The rod is moving in a plane, and the disk is attached at a point P on its boundary to the non-fixed end of the rod, in such a way that it can freely rotate about P in the plane in which the rod is moving.
Obtain the Lagrangian and the equations of motion.
I suppose I should divide this into two parts; one for the rod and one for the disk.
For the rod I get
[tex]T_1 = \frac{1}{2} I_1 \dot{\theta}_1^2 + \frac{1}{2} m(\dot{x}_1^2 + \dot{y}_1^2)[/tex]
,where the index 1 is the rod, and
[tex]V_1 = mgh = mg \frac{l}{2} (1 - \cos \theta_1)[/tex].
The moment of inertia for the rod is
[tex]I_1 = \frac{1}{3} m l^2[/tex].
So far so good, I think.. But how should I do with the disc? Should I treat this the same way and just use a superposition of the two lagrangians? And how do I get the moment of inertia?
Can you post a picture ? I'm unable to imagine the setup.
Daniel.
P.S. There's no such thing as a superposition of lagrangians.
This is what I think it should look like. I guess it's like a double pendulum with two rigid bodies.
The double pendulum sounds right to me. The moment of inertia of the disk about its pivot point P can be obtained using the parallel axis theorem. I think you would want to use two angles as your generalized coordinates, one for the rod and one for the disk.
So the kinetic energies are just
[tex]T_{rod} = \frac{1}{2} I_O \dot{\theta}_1^2[/tex]
and
[tex]T_{disc} = \frac{1}{2} I_P \dot{\theta}_2^2[/tex]
or should I include translation movement aswell?
I get the equations of motion to be
[tex]0 = \mu \left[ l \ddot{\theta}_1 + R \dot{\theta}_2 \sin{(\theta_1 - \theta_2)} (\dot{\theta}_1 - \dot{\theta}_2 + \dot{\theta}_1 \dot{\theta}_2) + R \ddot{\theta}_2 \cos{(\theta_1 - \theta_2)} + g \sin{\theta_1} \right] + \frac{1}{2} mg \dot{\theta}_1 \sin{\theta_1}[/tex]
and
[tex]0 = R \ddot{\theta}_2 + l \ddot{\theta}_1 \cos{(\theta_1 - \theta_2)} - l \dot{\theta}_1^2 \sin{(\theta_1 - \theta_2)} + g \sin{\theta_2}[/tex]
where I have used R instead of [tex]\rho[/tex]
Could this be correct?
and
You will need translation and rotation for the disk- translation of the CM and rotation about the CM. I did not look at your equations of motion yet. Did you include more than what you have here?
Yes I used
and
[tex]T_{disc} = \frac{1}{2} I_P \dot{\theta}_2^2 + \frac{1}{2} m (\dot{x}_2^2 + \dot{y}_2^2)[/tex]
where [tex]I_O[/tex] is the moment of inertia about the upper end of the rod, [tex]I_P[/tex] is the moment of inertia about the pivot point P and [tex]x_2[/tex] and [tex]y_2[/tex] are the coordinates of the c.m. of the disc.
Logarythmic said:
Yes I used
and
With x and y the coordinates of the CM, then the I for the disc should be the I about the center of mass.
But if I'm using I about P, what should I include then?
You could express the moment of inertia about the center of mass in terms of the moment of inertia about P by using the parallel axis theorem, but why would you want to? The CM is a special point in an assembly of particles or a rigid body that (among other things) permits the separation of kinetic energy into the translation of the CM term and the rotation about the CM term. No arbitrary point is so well behaved.
When you used x and y translational velocities for part of the kinetic energy, you were already including some of the energy of rotation about P. If you use I about point P, you will be couble counting some of the energy contribution.
So
and
[tex]T_{disc} = \frac{1}{2} I_{CM} \dot{\theta}_2^2 + \frac{1}{2} m (\dot{x}_2^2 + \dot{y}_2^2)[/tex]
is correct?
Logarythmic said:
So
and
is correct?
Looks right to me. With Io being the moment of inertial of the rod about its end.
For what it's worth, I found it easier to do the algebra using the angle between the radius from P to the disk center and the vertical. That would be the sum of your angles I believe. When the algebra is done it can be expressed in terms of your angles.
That's how I've done it. =) Thanks for your help!
which one is right?
Could you explain a little?
