| Thread Closed |
Extreme Period for a Physical Pendulum |
Share Thread |
| Nov29-06, 06:01 PM | #1 |
![]() solid, uniform disk of mass M and radius a may be rotated about any axis parallel to the disk axis, at variable distances from the center of the disk If you use this disk as a pendulum bob, what is T(d), the period of the pendulum, if the axis is a distance d from the center of mass of the disk? and The period of the pendulum has an extremum (a local maximum or a local minimum) for some value of d between zero and infinity. Is it a local maximum or a local minimum? 2. Relevant equations From the picture, I come up with the moment of inertia of the solid disk around its center of mass I = 1/2Ma^2 From the question, we are asked to find the period of the pendulum if the axis distance d from the center of mass. The period T for this is P= 2pi (sqrt L/g) where g is the gravitation force and L is the lenght. From my understanding is that because of the new lenght, we need to use the Parallel Theorem to find the new lenght I am not sure about this, so hope someone can help Iend = Icm + Md^2 Iend = 1/2Ma^2 + Md^2 So the period is P = 2pi (sqrt(( a^2 +d^2)/g)) But this is not correct. Thank |
| Nov29-06, 06:16 PM | #2 |
Recognitions:
Good thoughts, but your expression for the period doesn't seem correct. You may want to look at this: http://hyperphysics.phy-astr.gsu.edu/hbase/pendp.html. Your period expression has to include the moment of inertia.
| Nov29-06, 06:59 PM | #3 |
I = 1/2Ma^2 P = P= 2pi (sqrt 1/2Ma^2/(1/2Mgd^2)) == then we can cancel out the M to get P = 2pi (sqrt 1/2a^2/(1/2gD^2)) === cancel 1/2 === P = sqrt(a^2/gd^2) |
| Nov29-06, 07:50 PM | #4 |
Recognitions:
Extreme Period for a Physical Pendulumhttp://hyperphysics.phy-astr.gsu.edu...parax.html#pax |
| Nov30-06, 08:53 AM | #5 |
Is this the correct moment of inertia of the disk about the pivot point. I= 1/2Ma^2 + Md^2 = M ( 1/2a^2 + d^2) So the period of the disk is P = 2pi (sqrt (M(1/2a^2 + d^2)) |
| Nov30-06, 09:18 AM | #6 |
Recognitions:
http://hyperphysics.phy-astr.gsu.edu/hbase/pendp.html |
| Nov30-06, 11:17 AM | #7 |
P = 2pi(sqrt(a^2/2gd + d/g)) If you look at this, how can you determine whether it has a local maximum or local minimum for some value of d? |
| Nov30-06, 11:35 AM | #8 |
Recognitions:
| Thread Closed |
Similar discussions for: Extreme Period for a Physical Pendulum
| Simple Pendulum Motion and Physical Pendulum | Introductory Physics Homework | 6 | ||
| Period of a pendulum? | Introductory Physics Homework | 2 | ||
| The period of a pendulum | Classical Physics | 10 | ||
| Pendulum period | Advanced Physics Homework | 9 | ||
| Period of a pendulum | Calculus & Beyond Homework | 3 | ||
