Calculating Energy Needed to Melt an Ice Cube
  • Thread starter Thread starter fishingaddictr
    Cube Energy Ice
The original poster is attempting to calculate the energy required to completely melt an ice cube with a specified mass and initial temperature. The problem involves concepts from thermodynamics, specifically related to heat transfer and phase changes.
  • Participants discuss the use of the specific heat equation and the need to account for the latent heat of fusion. There is an exploration of the steps involved in calculating the total energy required for both heating the ice and melting it.
Some participants have provided guidance on the necessary calculations, noting that the original poster had initially overlooked the latent heat aspect of the problem. The discussion reflects a progression towards a more complete understanding of the energy calculations involved.
The original poster expresses uncertainty about their initial calculations and the approach needed to arrive at the correct answer. There is an acknowledgment of the importance of considering both the heating of the ice and the phase change to water.
fishingaddictr
How much energy is necessary to completely melt an ice cube of mass 360.6grams that is initially at a temp of -25.2 degrees celsius.
im thinkin i should use specific heat equation? is that right?
c=Q/m(change of temp)
2090=Q/.36069(25.2)
Q= 18992
i kno its wrong but I am not sure what approach i need to take in finding the correct answer.
the correct answer is 1.40x10^5
anyone? help please?
You've done one part of the calculation. You've found the energy it takes to heat the ice from -25.2C to 0C, but it's still ice at 0C. You now need to convert this ice into water. How much energy does it take to do that?
Look up the what the term 'Latent Heat' means.
ahhh ok.. i knew i missed sumthin important
so ... .3606x25.2x2090= 18992.0808
then i use the latent heat of fusion for water and get .3606x(33.5x10^5)=120801
combine them 18992.0808+120801= 139793.0808 --> 1.4x10^5
thank you gokul
  • · Replies 16 ·
