A solved problem from Griffiths creats problem
  • Context: Graduate
  • Thread starter Thread starter Kolahal Bhattacharya
    Griffiths
The discussion focuses on the vector potential of an infinite solenoid with n turns per unit length, radius R, and current I, as described in Griffiths' work. It emphasizes the application of Ampere's law, specifically the integral form correlating the closed integral of A.dl to the surface integral of B.da. The magnetic field B is defined as (μ)nI, resulting in a uniform axial field, while the vector potential A is circumferential. The analogy drawn by Griffiths between the solenoid and a fat wire carrying uniformly distributed current is critically examined, prompting further exploration of the justification for this analogy.
  • Understanding of Ampere's Law and its integral form
  • Familiarity with vector potential and magnetic fields
  • Knowledge of Griffiths' Electrodynamics concepts
  • Basic proficiency in LaTeX for mathematical expressions
  • Study the derivation of vector potential in electromagnetic theory
  • Learn about the application of Ampere's Law to different geometries
  • Explore the properties of magnetic fields around fat wires
  • Practice using LaTeX for formatting mathematical equations
Students and professionals in physics, particularly those studying electromagnetism, as well as anyone interested in advanced applications of vector potentials and magnetic fields.
A solved problem from Griffiths creats problem.It requires some discussion...It asks to find vector potential of an infinite solenoid with n turns per unit length radius R and current I.
Griffiths correlates integral form of Ampere's law to [closed integral of A.dl=surface integarl B.da].I can find A from this, with B=(mu)nI,uniform axial field and A circumferential.
But Griffiths says something here which I cannot understand.Quoting him,"The present problem (with a uniform magnetic field (mu)nI inside the solenoid and no field outside) is analogous to the Ampere's law problem of a fat wire carrying a uniformly distributed current.The vector potential is 'circumferential' (it mimics the magnetic field of the wire)."
As it appears, Griffiths is talking about the case where a fat wire is carrying a line current.In this case, magnetiv field is circumferential...But what is its justification?
Try solving the problem for starts. What's the magnetic field for such a wire? Hint: you can still use Ampere's law for it.
Also, it would be very helpful if you took at look at https://www.physicsforums.com/showthread.php?t=8997 It makes reading posts with math infinitely easier, and if you're going to be a physicist, you're going to have to learn LaTeX sooner or later, anyway.
