New Reply
What exactly is a zero radius turn vehicle?
Share Thread Thread Tools
Dec1-06, 02:45 PM   #1
Well for my project in 6th sem, i'm planning to make a zero radius turn vehicle. What i understand by a zero radius turning vehicle is that it should keep the centre of mass at a fixed position and then rotate so that it moves 180 degrees. That is the maximum movement i should be able to show i guess.
Am i right in my concept??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Dec1-06, 02:55 PM   #2
Certianly sounds like "turn on a dime" to me.
Dec1-06, 02:57 PM   #3
Recognitions:
Gold Membership Gold Member
A helicopter can do it.
Dec1-06, 03:00 PM   #4
Recognitions:
So can some lawn mowers and tanks and fork lifts.
Dec1-06, 04:43 PM   #5
Recognitions:
And skid-steer loaders, excavators, bulldozers, supermarket trolleys....
Dec1-06, 06:11 PM   #6
Recognitions:
I'm not sure, but I think that the Jeep Hurricane can as well; it has 4-wheel steering.
Dec2-06, 06:36 AM   #7
so you feel that my idea is correct. i know how to make it work. only thing is that i should not be making something else. and how on earth does a 4 wheel steering work
Dec2-06, 06:37 AM   #8
by the way, i know a helicopter can do it. but it does not have to rotate wheels to do it. its very different for a helicopter and a 4 wheeled vehicle i guess
Dec2-06, 09:04 AM   #9
Recognitions:
Yes they're different. That wasn't the point.
For a 4 wheeled vehicle or tracked vehicle to do a zero radius turn, the two opposing sides drive wheels must be able to rotate in opposite directions at the same time.
Dec2-06, 10:12 AM   #10
that is exactly what i'm planning to do....make the two diagonally opposite wheels rotate in opposite directions
Dec2-06, 10:51 AM   #11
Recognitions:
Here's an article about the Hurricane.
http://www.gizmag.com/go/3599/
and another:
http://auto.howstuffworks.com/jeep-hurricane.htm
Dec4-06, 10:27 AM   #12
well the both the articles are a great read. but what the howstuffworks article says is using a different concept of turning all the wheels in particular directions resulting in net 360 degree turn. not the way of couple that i thought or suggested.....
Dec4-06, 11:18 AM   #13
Mentor
Wow, yeah, I was gonna say that 4 wheel steering alone won't get you zero turn radius, but that's crazy how they applied it to that Jeep.
Dec5-06, 07:55 AM   #14
but just give it a thought..... how do they plan to move the 4 wheels differently.... when in normal conditions they can't do it
Dec5-06, 08:54 AM   #15
Recognitions:
You probably just switch modes with a dash control and the rest is done by computer. This is not the only on-off road vehicle with 4-wheel steering; it's just the most extreme example of it.
By the way, I didn't realize until I reread the article that it won't be put into production.
Dec5-06, 09:06 AM   #16
Recognitions:
Quote by Danger View Post
LOL You do realize it had TWO engines in it, right?! While an interesting concept, what a nightmare if you wanted to buy one.
Exotic, yes. Impractical, absolutely.
Dec5-06, 09:26 AM   #17
Recognitions:
Not just 2 engines--2 Hemis.
As mentioned elsewhere, my grocery-getter is a 4WD El Camino with 33" tires and a 455 Olds Rocket motor, so practicality has never been near the top of my priority list.
New Reply
Thread Tools
Similar Threads for: What exactly is a zero radius turn vehicle?
Thread Forum Replies
Turning radius of a ZTR vehicle with two different wheel velocities Classical Physics 7
Rate Of Turn and Turn Radius of an aircraft Introductory Physics Homework 2
Ski Turn Radius, Inclination at Speed & Balance Introductory Physics Homework 1
Turning Radius of a floating vehicle in water Mechanical Engineering 0
Motorcycle: Lean Angle, Speed, and Turn Radius Classical Physics 0
