Prove Rhombus Diagonals Perpendicular: Vector Homework
  • Thread starter Thread starter prace
    Proof Vector
The discussion centers on proving that the diagonals of a parallelogram are perpendicular if and only if the parallelogram is a rhombus. The key equation used is the dot product, specifically (a+b)·(a-b) = 0, which indicates that the vectors a and b must have equal magnitudes for the diagonals to be perpendicular. The proof is established by expanding the dot product and simplifying to a² - b² = 0, confirming that a² = b² when the diagonals are perpendicular.
  • Understanding of vector operations, specifically dot products
  • Familiarity with properties of parallelograms and rhombuses
  • Basic knowledge of algebraic manipulation of equations
  • Ability to interpret geometric representations of vectors
  • Study vector geometry and properties of quadrilaterals
  • Learn about the implications of the dot product in vector analysis
  • Explore proofs involving geometric shapes and their properties
  • Investigate the relationship between vector magnitudes and angles
Students studying geometry, particularly those focusing on vector analysis and properties of quadrilaterals, as well as educators seeking to enhance their understanding of geometric proofs.
prace
Prove that the diagonals of a paraelogram are perpendicular iff the parallelogram is a rhombus.
a (dot) b = 0
This is how I started:
By definition, a rhombus is a quadrilateral with all sides equal in length. So this means that if I have two vectors, a and b that form the corner of a rhombus, then that means that the magintude of a and b are equal. By inspection of a diagram of this vector problem, I found that (a+b) (dot) (a-b) = 0 iff the magintude of a and b are equal.
This is great, however, it will not fly because I cannot just say "by inspection of the diagram" right. How can I put this in words that will make my proof make sense?
Thanks
The diagonals of the parallelogram are precisely a+b and a-b. if you are talking about proving your equation above, multiply it out, keeping in mind:
[tex](a+b)\cdot (a-b) = a\cdot a - b\cdot b + b\cdot a - a\cdot b[/tex]
edit: fixed my mistake
[tex](a+b)\cdot (a-b) = a\cdot a + b\cdot b + b\cdot a - a\cdot b[/tex]
AWESOME! Thank you so much for you help. That was a lot easier than I thought. So, after multiplying it out, I came up with a²-b²=0. So this is true iff a² = b². Thanks for your help!
