Plane Wave Propogation (help understanding steps in book)
  • Thread starter Thread starter FrogPad
    Book Plane Wave
The discussion focuses on the derivation of the equation for plane wave propagation, specifically the magnetic field vector \(\vec H\) at time \(t = 3 \, \text{ms}\). The solution provided is \(\vec H = \hat z 4 \times 10^{-6} \cos \left(10^7 \pi t - k_0 y +\frac{\pi}{4} \right)\), with \(k_0\) calculated as \(0.105 \, \text{rad/m}\) and wavelength \(\lambda = 60 \, \text{m}\). The critical step involves recognizing that the term \(10^7 \pi (3 \times 10^{-3})\) is a multiple of \(\pi\), allowing it to be dropped without affecting the cosine function's zero crossings. The final expression for \(y\) is derived as \(y = \pm 30n - 7.5 \, \text{m}\), where \(n\) is an integer.
  • Understanding of electromagnetic wave propagation
  • Familiarity with trigonometric functions and their properties
  • Knowledge of wave number \(k_0\) and its calculation
  • Basic grasp of angular frequency and its role in wave equations
  • Study the derivation of wave equations in electromagnetic theory
  • Learn about the properties of cosine functions and their phase shifts
  • Explore the implications of dropping terms in wave equations
  • Investigate the physical significance of wave number and wavelength in wave propagation
Students and professionals in physics and electrical engineering, particularly those studying wave propagation and electromagnetic theory.
FrogPad
Plane Wave Propagation (help understanding steps in book)
Basically this problem requires that [itex]\vec H[/itex] vanishes at [itex]t = 3ms[/itex]. I don't understand how they did the last step, here is the solution:
[tex]\vec H = \hat z 4 \times 10^{-6} \cos \left(10^7 \pi t - k_0 y +\frac{\pi}{4} \right)[/tex]
[tex]k_0 = \omega \sqrt{\mu_0 \epsilon_0} = \frac{10^7 \pi}{3 \times 10^8} = 0.105 \,\,\,\, (rad/m)[/tex]
[tex]\lambda = \frac{2\pi}{k_0} = 60 \,\,\,\, (m)[/tex]
At [itex]t = 3 \times 10^{-3} \,\,\,\, (s)[/itex] we require the argument of cosine in [itex]\vec H[/itex]:
[tex]10^7 \pi (3 \times 10^{-3}) - \frac{\pi}{30}y +\frac{\pi}{4} = \pm n \pi + \frac{\pi}{2}, \,\,\,\,n=0,1,2,\ldots[/tex]
[tex]y = \pm 30n - 7.5 \,\,\,\, (m)[/tex]
Now how the hell do they get the last line? The... [itex]y = \pm 30n - 7.5 \,\,\,\, (m)[/itex] (Lets call this (1)) line.
They drop [itex]10^7 \pi (3 \times 10^{-3})[/itex] why?
My problem is that if we plug in (1) into,
and set t = 0.003, then if we feed the function values of n then the cosine doesn't drop to 0.
Thanks in advance!
The term they dropped is a multiple of pi (and in fact a multiple of 2pi). Adding a multiple of pi to an angle at which the cosine is zero is still going to give you a cosine of zero.
Ahh... tricky tricky. (I mean, yeah, it's not too tricky but still, I guess I will add this to my list of things to look for subconsciously while evaluating expressions)
