Heisenberg uncertainty principle
The discussion centers around the Heisenberg uncertainty principle, specifically the definitions and interpretations of the symbols ∆x and ∆p in relation to uncertainty measurements. Participants explore the differences between various formulations of the principle, including the use of standard deviation versus root mean square (rms) values, and the implications of these definitions in practical scenarios.
  • Some participants note that the expression ∆x∆p = ℏ requires a different interpretation of ∆ compared to ∆x∆p = ℏ/2, suggesting that the former does not represent standard deviation but rather a deviation covering 50% of possible values.
  • Others argue that the definitions of uncertainty in terms of standard deviation and rms are not equivalent, leading to confusion about their application in the context of the uncertainty principle.
  • A participant expresses uncertainty about how to determine whether to use standard deviation or rms values in practical examples, indicating that the definitions may vary across different resources.
  • Some participants highlight that the mathematical definitions of standard deviation and rms should be clarified, as they may not align with the definitions used in the original book referenced.
  • There is a suggestion that the notation used for deviations could be improved to avoid confusion, particularly regarding the use of the same symbol for different concepts.
Participants do not reach a consensus on the definitions and implications of ∆x and ∆p, with multiple competing views remaining regarding their interpretations and applications in the context of the Heisenberg uncertainty principle.
Participants mention that the definitions of uncertainty may depend on the context and the specific resources being referenced, leading to potential misunderstandings in their application.
ovoleg
Hey guys I have a few questions...
My book defines the Heisenberg uncertainty principle by
∆x∆Px >= aitch-bar
All other resources I have have it stated as
∆x∆Px >= aitch-bar/2. They mention that ∆Px and ∆x represent the rms values of independent measurements.
My book represents ∆x and ∆Px as the standard-deviation uncertanties right..
So say for instance you get a general question like x-cordinate of a proton is measured with uncertainty of 1.3mm. What is the xcomponent of velocity to the minimum percentage of uncertainty of 33%.
would you take ∆x as the standard deviation uncertanties or rms values ?
It seems like it varies from book to book but in general shouldn't this be the same? Say someone posed a question like this online, how would I know what to use?
When you have:
[tex]\Delta x \Delta p = \hbar[/tex]
The [itex]\Delta[/itex]'s do not mean the standard deviation, but instead the deviation which covers 50% of the possible values. When we have:
[tex]\Delta x \Delta p = \frac{\hbar}{2}[/tex]
It requires that [itex]\Delta[/itex] be the standard deviation.
AFAIK, both of these are only actually correct when x and p are normally distributed.
Hope this clears that up for you.
Jheriko said:
When you have:
I'm still a bit confused as to how both of them could be correct?
Makes sense that if delta(x) is one standard deviation then in the first one it covers half the values, but then how are these two equivalent?
Also, rms does not equal a standard deviation as far as I know...
I'm confused :/
I'm confused :/
First off I made some nasty typos in my tex and the equalses should be greater than or equal tos.
[tex]\Delta x \Delta p & \ge \hbar[/tex]
[tex]\Delta x \Delta p & \ge \frac{\hbar}{2}[/tex]
Secondly, the important point is that in the first equation the delta does NOT represent a standard deviation. A standard deviation covers some percentage of the values that I can never remember... ~68% apparently. The required deviation for the first form uses the size of the range which covers
50% of the values. Its just confusing that the same symbol gets used, it might be better to have
[tex]\Delta_{50\%} x \Delta_{50\%} p & \ge \hbar[/tex]
This is not standard though, and just something I made up on the spot.
I don't know where the root mean square is coming from...
if it was 50% of each then it would be aitch-bar/4?
:( I'm lost
We often call it that because we define the uncertainty in x as
[tex]\Delta x \equiv \sqrt{<(x - <x>)^2>}[/tex]
i.e. as the square root of the mean of the square of the difference between x and its mean. In QM of course we speak of "expectation value" rather than "mean" in this context.
I think we define [itex]\Delta x[/itex] this way because it has nice mathematical properties as compared to other ways that we could define it.
Well as the example that I posed initially, how would you determine what the delta values are? Are they standard deviations or are they rms ?
and it doesn't seem to be as nice of a relationship when you compare rms and a standard deviation(1/2)
First, what are your definitions of "standard deviation" and "rms"? To me, they mean basically the same thing. But the important thing is the mathematical definition, not the words.
For the definitions of [itex]\Delta x[/itex] and [itex]\Delta p[/itex] that your book is using, you had best look for them in the book itself. Whatever they're using, it isn't the standard definition. Mathematically, the standard definition (in terms of expectation values) is the one that I gave, and it leads to [itex]\Delta x \Delta p \ge \hbar/2[/itex].
Either your book's [itex]\Delta x \Delta p \ge \hbar[/itex] is a typographical error, or the author is being a bit sloppy by neglecting numerical constants, or he's using a non-standard definition of [itex]\Delta x[/itex] and [itex]\Delta p[/itex] that is different from the standard one by a factor of [itex]\sqrt{2}[/itex].
Thanks, actually I had to look up rms and "standard deviation" and they do differ...but not nicely for me to rearrange the equation to remove the constant.
It does seem like he has a different defition for Delta(x) and Delta(p) but the problems are worded in a way that can be interpreted with either inequality which is misleading because I am not sure which one to use...
I was just curious on who else would see this type of definition.
Thanks again!
  • · Replies 32 ·
  • · Replies 54 ·
  • · Replies 71 ·
9K
