What Gauge Pressure is Needed for a Water Jet to Reach 29.8 m/s?
  • Thread starter Thread starter RED20
    Fluids Physics
The discussion centers on calculating the gauge air pressure required in a fire extinguisher to achieve a water jet speed of 29.8 m/s, with the water level 0.515 m below the nozzle. Participants utilized Bernoulli's equation, specifically the form: p1 + 1/2 * ρ * v1² + ρ * g * y1 = p2 + 1/2 * ρ * v2² + ρ * g * y2. The initial attempt to solve for p2 resulted in an incorrect value of -4.49 x 10^5 Pa, indicating a misunderstanding of the variables, particularly the height terms in relation to the nozzle position.
  • Understanding of Bernoulli's equation and its components
  • Knowledge of fluid dynamics principles
  • Familiarity with gauge pressure concepts
  • Ability to manipulate algebraic equations
  • Review the application of Bernoulli's equation in fluid dynamics
  • Study the concept of gauge pressure versus absolute pressure
  • Learn about the effects of height differences in fluid flow calculations
  • Practice solving fluid dynamics problems involving varying heights and velocities
Students studying physics, particularly those focusing on fluid dynamics, engineers working with fluid systems, and anyone involved in pressure calculations in practical applications.
RED20
Help! Physics Fluids problem
Water is forced out of a fire extinguisher by air pressure. How much gauge air pressure in the tank (above atmospheric) is required for the water jet to have a speed of 29.8 m/s when the water level is d=0.515 m below the nozzle?
I tried using bernoulli's equation, p1+ 1/2*p*v1^2 + p*g*y1= p2 + 1/2*p*v2^2 + p*g*y2
I am not sure what variables I am supposed to put in where, as the diagram i am given in the question is that of a tank with a water pipe in the middle of it.
I attempted to solve for p2, using p1 as atmospheric pressure, density as the density of water, v1 as 29.8m/s^2, height as 0.515. The rest of the terms on the second half of the equation I thought would cancel because the height would be 0 and I thought the starting velocity is 0. I ended up getting -4.49 x 10^5 Pa...which isn't right...please help!
The height of the water in the jet is below the nozzle. I think you want to either make y1 negative, or make it zero and use the .515m for y2.
  • · Replies 16 ·
  • · Replies 84 ·
9K
