| Thread Closed |
Heat Pump |
Share Thread | Thread Tools |
| Dec4-06, 02:12 PM | #1 |
Heat Pump
It is proposed to heat a house using a heat pump operating between the house (27 degees) and the outside (-13 degrees). The heat loss from the house is 7kW. What is the minimum power required to operate the heat pump? 2. Relevant equations 3. The attempt at a solution e=Th/(Th-Tc) =7.5 W=7000/7.5 =933 W Just checking if this is correct or have I made a mistake. Thanks |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Dec4-06, 04:05 PM | #2 |
Recognitions:
Since you start out with a dimensionless number, a ratio of temperatures, and equate that to some number of Watts, something is surely wrong. Maybe you just need to rewrite things to make it clear
| Dec4-06, 04:46 PM | #3 |
I have moved the equation now. If you look at the question you will see that 7000 has units of watts. Is it wrong anyway?
| Dec4-06, 11:39 PM | #4 |
Recognitions:
Heat Pump |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Heat Pump
| Heat Pump | Introductory Physics Homework | 6 | ||
| Home heat pump | Advanced Physics Homework | 3 | ||
| Heat Pump | Introductory Physics Homework | 3 | ||
| Heat pump cycle | Introductory Physics Homework | 2 | ||
