Mass of a Spring: Does it Affect the Period?
  • Thread starter Thread starter courtney1121
    Mass Spring
The discussion revolves around the impact of a spring's mass on the period of a harmonic oscillator, specifically questioning whether this mass alters the period compared to theoretical predictions based on the equation T= 2*pi*sqrt(m/k).
  • Exploratory, Assumption checking
  • Participants explore the relationship between the mass of the spring and the spring constant k, with one participant suggesting that variations in k could influence the period. Questions about the concept of effective mass are also raised.
The discussion is ongoing, with participants sharing resources and seeking clarification on the concept of effective mass. Some guidance has been provided through external links, but no consensus has been reached regarding the relationship between the spring's mass and the period.
Participants are encouraged to research further into the concept of effective mass, indicating a potential gap in understanding that is being addressed through external resources.
courtney1121
Any real spring has mass. Do you think that this mass would make the actual period of a real harmonic oscillator longer or shorter than the period predicted by the equation T= 2*pi*square root m/k. Explain your reasoning.
I think it will affect the period because I am thinking that the mass of the spring will determine the value for k. So if k is varying then, yes it will affect the period.
Does it make sense that the mass of the spring is related to k?
This might give you a small clue: http://www.emporia.edu/physics/keithron/collegelab2/shm.htm" .
What does the effective mass of the spring mean?
This is the point at which you should do some google-ing, since I'm powerless in further explanation. :wink:
lol ok and thanks so much for that website, it definitely helped. It was exactly what I was looking for.
  • · Replies 56 ·
