Installing Pro-Engineer on a linux machine
  • Thread starter Thread starter dichotomy
    Linux Machine
The discussion centers around the process of installing Pro-Engineer (Wildfire 3 version) on a Linux machine, specifically a Debian distribution. Participants share their experiences and seek guidance on installation methods, given the original poster's limited experience with Linux.
  • Homework-related, Technical explanation, Exploratory
  • One participant expresses a lack of experience with Linux and seeks help for installing Pro-Engineer.
  • Another participant suggests a tutorial for installing software from source on Ubuntu, noting that it may be applicable to Debian-based systems, but recommends waiting for confirmation.
  • A different participant points to a blog post that may contain installation instructions from the manufacturer, indicating that such instructions are typically found in files like "INSTALL" or "README".
  • One participant mentions having only archive files and describes an unsuccessful attempt to run the setup script.
  • Another participant proposes specific commands to initiate the installation process and requests further information if those commands do not work.
Participants do not reach a consensus on the installation process, as there are varying suggestions and experiences shared. The discussion remains unresolved regarding the specific steps needed to successfully install Pro-Engineer.
Participants acknowledge limitations in their knowledge and experience with Linux, which may affect the reliability of the advice given. There is also uncertainty regarding the availability of installation media and the specific requirements for running the setup script.
Individuals new to Linux who are attempting to install software, particularly those interested in Pro-Engineer or similar applications on Debian-based systems.
dichotomy
anyone know how to do this? i have 0 experience installing stuff on linux, I'm pretty new to it. i know the one word "un-tarring" and that's about the limit of my capabilities
it'll be wildfire3 version of proe on debian distro
thanks for any and all help
Computer science news on Phys.org
http://www.psychocats.net/ubuntu/installingsoftware
Scroll down that page till the point where it says:
"4. Installing from source"
That is actually a tutorial for Ubuntu (a Debian-based distro), so I think it should work for the most part. You might just want to wait for a confirmation from someone else, since I am new to Linux, too. FYI, if you can find a .deb file for the same program, then it would be as simple as installing a program on Windows.
You could take a look at this:
http://blogs.ittoolbox.com/linux/locutus/archives/how-to-install-proengineer-under-linux-12695
The manufacturer should have left instructions on how to install. Usually its in a file called "INSTALL" or "README".
ahh see I don't have solid media, only archive files to be unpacked. i have done so, and tried to run /home/(username)/.../setup, but it does nay work.
Mayb you can start the installation by doing the following:
cd /home/(username)/...
sh setup
OR (from within the install directory)
./setup
If that doesn't work, post the output of ls -al from within the install directory.
  • · Replies 18 ·
  • · Replies 27 ·
19K
