Equation for Floating Ball in Air Jet: F=ma
  • Context: Undergrad
  • Thread starter Thread starter skin
The discussion centers on calculating the forces acting on a floating ball in an air jet, specifically using the equation F=ma. The ball's mass is given as 2g (0.002kg), and the gravitational force acting downwards is calculated to be 0.0196N. Participants suggest exploring the drag coefficient equation to determine the upward force acting on the ball, while acknowledging the complexity of deriving a single equation for this scenario. The consensus indicates that a mathematical model may be necessary, but a closed-form solution is not guaranteed.
  • Understanding of Newton's Second Law (F=ma)
  • Basic knowledge of fluid dynamics and drag coefficients
  • Familiarity with gravitational force calculations
  • Ability to interpret mathematical models in physics
  • Research the drag coefficient equation and its application in fluid dynamics
  • Explore mathematical modeling techniques for dynamic systems
  • Study the principles of buoyancy and its relation to floating objects
  • Investigate numerical methods for solving complex equations in physics
Physics students, engineers, and anyone interested in fluid dynamics and force calculations in dynamic systems.
skin
Is anybody aware of an equation that can be used to describe a floating ball in an air jet?
http://www.ap.stmarys.ca/demos/content/fluids/bernoulli_floating_ball/bernoulli_floating_ball.html
I'd just like to put numbers into an equation and prove that the forces on either side of the ball are equal.
the balls mass is 2g
take gravity as 9.81ms ?
F=ma (0.002kg x 9.81) = 0.0196N
that should be the component of force acting downwards upon the ball, would you agree?
Now i'd like to find a way of calculating the force acting up on the ball, which I'd expect to be close to the figure above. Any suggestions ?
I don't know if I'm on the right track because I'm a bit thick but should I be looking into the drag coefficient equation ?
I do not think that you will find a single simple equation which will do what you want. One could create a mathematical model of this situation, but I cannot guarantee that the resulting system of equations would have a closed form solution.
i'm probably just better off saying that it follows Newtons 2nd law. Thnx for reply anyway :)
