Minimum Collision Speed for Excitation of Hydrogen Atoms
The discussion revolves around the minimum collision speed required for two hydrogen atoms to be excited from the ground state to the n=2 level. Participants are exploring the relationship between energy and speed in the context of atomic excitation during a head-on collision.
  • Participants discuss using angular momentum and energy equations to determine the minimum speed. There is uncertainty about how to correctly apply these equations, particularly in relation to the mass of the electron versus the proton and the energy required for excitation.
Some participants have provided guidance on equating the energy required for excitation to the kinetic energy of the atoms. Others are questioning their calculations and conversions, indicating a mix of interpretations and attempts to clarify the problem.
There are mentions of specific energy values for the ground and n=2 states, as well as confusion regarding unit conversions and the application of formulas. Participants are working within the constraints of the problem as presented, without additional context or information.
cocomisk
Two hydrogen atoms, both initially in the ground state, undergo a head on collision. If both atoms are to be excited to the n=2 level in this collision, what is the minimum speed each atom can have before the collision?
Ke = 8.99 *10^9
e = 1.602 *10^-19
ħ = 1.05 * 10 ^-34
Mass of electron = 9.11 * 10^-31
mass of proton = .672 * 10^-27
Mass of electron*v*r = nħ This is the angular momentum equation
Total Energy= 1/2 mv^2 - Ke *(e^2 / r)
v^2 = (n^2 * ħ)/(m^2*r^2) = (Ke*e^2)/(m*r)
Radius of n = n^2 * .0529 nm
I can't figure out how to use angular momentum to solve this and that's the only equation my book provides for momentum concerning hydrogen. The closest I have come is using the v^2 equation and using the proton mass rather than the electron mass and using the radius for n=1. This gives me 51043 m/s. The answer is supposed to be 44200 m/s. I assume I need to incorporate the changes in velocity somehow, but I can't figure out how to format an equation to do that.:confused:
Any help is greatly appreciated!
~Courtney
I think this is a lot more simple than you're trying to make it. All you need to know is how much energy it takes to get an electron into the n=2 level and then make that equal to the kinetic energy of the atoms and solve for speed. Because the collision is head on you can assume all the energy goes into making the electron jump to the n=2 level.
E of the ground state = 13.6 eV
E of the n=2 state = 3.4 eV
So the energy required is 10.2 eV or about 6.367 *10^19 J
When I set this equal to 1/2 mv^2, I get a huge number for v...like numbers *10^23. That's incredibly far from the listed answer. What am I doing wrong?
The energy should be 6.367x10-19 should get a more reasonable answer like 15 000 m/s.
Yeah I just realized I was converting the numbers wrong.
Thanks Kurdt.
no problem :smile:
  • · Replies 22 ·
18K
