How to Calculate the Force to Unstick an Expanding Copper Pipe?
The discussion revolves around a physics problem involving the thermal expansion of a copper pipe and the force required to unstick it as it expands. The context includes the pipe's dimensions, temperature changes, and the mechanics of how the pipe interacts with its surroundings.
  • Participants discuss the calculations related to thermal expansion and the force needed to compress the pipe. Questions arise regarding the interpretation of the cross-sectional area and the application of the elastic modulus of copper. Some participants explore the implications of the pipe achieving a relaxed state after each tick.
There is ongoing exploration of the problem, with participants offering insights into the necessary parameters for calculating the force. Some guidance has been provided regarding the relationship between elasticity, area, and movement, but no consensus has been reached on the exact method to apply.
Participants note the lack of specific information about the existing forces acting on the pipe and the assumptions made regarding its behavior during thermal expansion. The discussion reflects uncertainty about the validity of certain assumptions related to the mechanics of the pipe's movement.
PhysicsMiester
1. When the hot water in a certain upstairs bathroom is turned on, a series of 18 "ticks" is heard as the copper hot-water pipe slowly heats up and increases in length. The pipe runs vertically from the hot-water heater in the basement, through a hole in the floor 5 m above the water heater. The "ticks" are caused by the pipe sticking in the hole in the floor until the tension in the expanding pipe is great enough to unstick the pipe, enabling it to jump a short distance through the hole. If the hot-water temperature is 50°C and room temperature is 20°C
This is a two part problem:
1st is a) the distance the pipe moves with each "tick"
Coefficient of Expansion is 17 x 10 ^-6 [(°C)^-1]
So to solve this all I did is following:
17 x 10 ^-6 [(°C)^-1] by 5 by 50°C = a
17 x 10 ^-6 [(°C)^-1] by 5 by 20°C = b
and then (a - b)/18 = 0.000146 meters
So here comes my question:
b) the force required to unstick the pipe if the cross-sectional area of the copper in the pipe is 3 x 10-5 m^2
I don't have an idea how to even approach this problem. If anyone can give me any clue it would be great
Thank you
For part b you need to know something about the force required to compress the pipe by the length of one tick movement. Note that the area given is the cross-sectional area of the copper in the pipe, not the cross-sectional area of the pipe.
Well I have found that the typical value for the elastic modulus of copper is 1.1 x 10^11 Pa. Now I have length of the pipe which is 5 meters, Cross-sectional area of the copper in the pipe in m^2, how much it moves with each tick (18 ticks as well) and typical value of elasticity of copper in N/m^2. I am still a little confused on how to solve this problem.
Assume that after each tick, the pipe achieves a relaxed state (no compression) As it heats up, its natual length increases by thermal expansion, but it is physically constrained to stay at one length. This requires a force, and the amount of force increases with temperature because the amount of compression from natural length is steadily increasing. When the force is no longer strong enough to keep the pipe compressed, it suddenly moves one tick to a new relaxed position.
The assumption of achieving a relaxed postion at each movement may not be completely valid, but you have not been given enough information to know exactly how much force is already acting after each move.
what else do you think I would need to solve this?
Nothing. You have all that is needed. Find out how much force it would take to compress the pipe by the length of one tick.
Should I multiply
elasticity of copper (N/m^2) by
cross-sectional area of the copper in the pipe (3 x 10-5 m^2)
multiple by the distance each tick the pipe moves
and divide by the distance of the pipe (5m)?
I would like to thank you for your help.
Thank you
  • · Replies 20 ·
12K
  • · Replies 17 ·
