Free Falling (dynamics question)
  • Thread starter Thread starter Raging Dragon
    Falling
The discussion focuses on calculating the point at which the kinetic energy (KE) of a skydiver equals the energy dissipated by drag forces during free fall. The skydiver jumps from a height of 9570.7 meters, with gravitational acceleration set at 9.81 m/s². The drag force is modeled using a combination of Stokes and Newtonian drag, represented by the equation Fdrag = -m*b*v - m*b²*v². The participant derives the velocity function v(t) and seeks clarification on integrating the drag force to find the energy dissipated.
  • Understanding of nonlinear ordinary differential equations (ODEs)
  • Familiarity with gravitational potential energy (GPE) and kinetic energy (KE)
  • Knowledge of drag force equations in physics
  • Ability to perform integration with respect to different variables
  • Study the integration of force functions with respect to velocity and time
  • Learn about energy conservation principles in physics
  • Explore advanced topics in drag force modeling, including Stokes and Newtonian drag
  • Investigate numerical methods for solving nonlinear ODEs
Students in physics, particularly those studying dynamics and energy conservation, as well as educators and professionals involved in fluid dynamics and motion analysis.
Raging Dragon
A sky diver jumps off a plane that is at 9570.7m above the earth. Assuming a combination of stokes and Newtonian drag, where Fdrag=-m*b*v-m*b^2*v^2 and assume constant g=9.81, at what point is the KE of the skydiver equal to the energy dissapated by the drag force?
Equating mg=Fdrag one can find b quite easily.
I've derived through solving a nonlinear ODE Fnet=m*vdot=m*g-m*b*v-m*b^2*v^ 2 that
v(t)=-10.10573478+64.10573477*tanh(.1569282379*t+.1589673340)
So I know that Gravitational Potential energy is =m*g*h=m*9.81*9570.7
Then I figure that PE=GPE (initially) for max h.
then when the sky diver jumps that PE=GPE+KE+Drag Energy
Now my question is to find the drag energy, do I integrate F_drag with respect to v, or t?
Then I take it that you need to also determine the time and distance fallen for this to happen, so then you goet PE-GPE=KE+Drag Energy and then KE=Drag Energy=(PE-GPE)/2
This make sense?
The energy dissipated by the drag force is the negative of the (negative) work it does on the diver, which is the integral of the force over the distance the diver falls.
Thanks for explaining what the boundary of the integral is, but against which variable if I have force as a function of velocity, and I have velocity as a function time?
