Diagram & Calculations for Pulley System with Masses 8kg, 2kg, and 4kg
  • Thread starter Thread starter mcintyre_ie
    Pulley
The discussion focuses on the dynamics of a pulley system involving masses of 8 kg, 2 kg, and 4 kg. The correct accelerations for the components are established as follows: Pulley A accelerates at g/11, Pulley C at 2g/11, and the particles at g/11 and 5g/11. The relationship between the movements of the pulleys is clarified, confirming that for every 1 meter Pulley A descends, Pulley C ascends 2 meters, resulting in Pulley C having twice the acceleration of Pulley A. A consistent sign convention is emphasized for accurate equation formulation.
  • Understanding of Newton's laws of motion
  • Familiarity with pulley systems and their mechanics
  • Knowledge of acceleration and forces in physics
  • Ability to apply consistent sign conventions in equations
  • Study the principles of Newton's second law in the context of pulley systems
  • Learn about the effects of mass distribution on acceleration in mechanical systems
  • Explore advanced topics in dynamics, such as tension in strings and frictionless surfaces
  • Practice solving problems involving multiple pulleys and varying mass configurations
Students of physics, mechanical engineers, and anyone interested in understanding the dynamics of pulley systems and their applications in real-world scenarios.
mcintyre_ie
I’d appreciate some help with the following question:
The diagram shows a light inextensible string
having one end fixed at O , passing under
a movable pulley A of mass 8 kg and
then over a fixed light pulley B.
The other end of the string is attached to
a light pulley C, of negligible mass.
Over pulley C , a second light inextensible
string is passed having particles of mass 2 and
4 kg respectively, attached. All pulleys are smooth.
(i) Show in a diagram the forces acting on each pulley when the system is released from rest.
(ii) Find the acceleration of
pulley A
pulley C
each particle.
Heres a link to the work I've done so far which i think i have correct (Ive spent about an hour working on my equations, but theyre not making much sense).
Work So Far
The correct answers are:
(ii)
Pulley A - g/11
Pulley C - 2g/11
Particles - g/11 and 5g/11
Im unsure if my accelerations are correct - would i be right in saying that for every 1m Pulley A falls, pulley C rises two metres, along with both particles? So that would mean pulley C has twice the acceleration of Pulley A? And both particles move with the acceleration f +/- 2a?
Thanks in advance for any help.
Almost, but not exactly. Yes, pulley C has twice the acceleration of pulley A (in magnitude). If you call the acceleration of pulley A "a" (down), then the acceleration of pulley C is "2a" (up). When you write out your equations, be sure to use a consistent sign convention. For example, the way I would look at it, your first equation should read 2S - 8g = -8a (since you've chosen up as positive).
Also, if "f" is the magnitude of the acceleration of the particles with respect to pulley C, then the full acceleration of the particles would be: 2a +/- f. Once again, use a consistent sign convention when writing the equations.
Thanks for your reply, I am constantly mixing up signs. Thanks again for your help.
  • · Replies 22 ·
  • · Replies 22 ·
11K
