Evaluating Integral and Series: Find Solution to ∫√(x³ +1)dx
  • Thread starter Thread starter merced
    Integral Series
The discussion revolves around evaluating the indefinite integral of the function √(x³ + 1) as an infinite series. Participants are exploring methods for integrating this expression, particularly in the context of series expansions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants suggest using Taylor or Maclaurin series to express the integrand as an infinite series. Others express uncertainty about how to apply these series to the specific integral given, noting that their textbooks provide examples for different functions.
There is a mix of attempts to clarify the use of infinite series and binomial expansion. Some participants have provided alternative methods, such as binomial expansion, while others are questioning the applicability of these methods to the integral in question. The conversation reflects a lack of consensus on the best approach to take.
Participants mention constraints such as limited coverage of relevant topics in their coursework and the need for more detailed explanations of infinite series and binomial expansions.
merced
1. Homework Statement Evaluate the indefinite integral as an infinite series.
[tex]\int{\sqrt{x^3 +1}}[/tex]
Taylor Series: f(x) = [tex]\Sigma_{n=0}^{inf} \frac{\f^{n}(a)}{n!} (x-a)^n[/tex]
Maclaurin Series --> taylor series with a = 0
I have no idea how to evaluate this integral. I can't use u substitution. From the chapter, I have seen no general formula for such an integral.
Please give a hint.
Firstly, I'm going to assume you meant to write [itex]\int \sqrt{x^3 + 1} \, dx[/itex].
merced said:
Please give a hint.
Read the problem!
Evaluate the indefinite integral as an infinite series.​
This suggests infinite series are going to be involved. Is there anything here you can write as an infinite series?
Yeah, I know that I'm supposed to use an infinite series...but my book only gives examples that are similar to e^x, sin x, cos x, [tex]tan^{-1}x[/tex], and 1/(1-x)...so I can't really think of what to do.
[tex]\int{\sqrt{x^3 +1}}[/tex] is not similar to any of those, except maybe the integral of [tex]tan^{-1}x[/tex].
Well, you've learned how to compute infinite series, haven't you? You could try that.
P.S. Your book doesn't have infinite series expressions for things like [itex]\sqrt{x+1}[/itex]?
Could you solve by first expanding the integrand using binomial expansion and then integrate each individual part?
Umm...I don't think so. My professor did not cover this section in the detail I would have liked.
I didn't quite understand everything in the section.
Please tell me how to compute infinite series! :)
I haven't gotten to binomial expansions yet.
Oh I see, well, just in case you want to know, the binomial expansion series says you can expand a binomial according to the following formula:
[tex]1+kx+\frac{k(k-1)}{2!}x^2+\frac{k(k-1)(k-2)}{3!}x^3[/tex] and so on, where k is your exponent.
In this integral, [tex]\int{\sqrt{x^3 +1}}[/tex] your function is raised to the (1/2) power so k = (1/2). Then you just simply plug in for x and k in the formula for a couple of terms and integrate each term individually.
I worked out your integral on my TI-89 and evaluated from 0 to 1 and got the answer 1.111448. When I worked it with the binomial expansion method (3 terms) I got 1.149. So you can see the values are pretty close. If I worked out more terms, my answer would have been any closer.
I know you want to use a different technique, but just in case you can't find it through your method, I just wanted to give you an alternative method to use. Hope it helps and I wish I could help you with the other way, but I am not too sure about that way.
You already know how!
As you've said (correcting the typos):
[tex]f(x) = \sum_{n=0}^{+\infty} \frac{f^{(n)}(a)}{n!} (x-a)^n[/tex]
at least... you know how to compute the first several terms of the infinite series. (And hopefuly, you can then figure out what the general term is)
Incidentally, the binomial formula you wrote is valid only when k is an integer. So advising him to plug k=1/2 is nonsensical.
Daniel.
Actually, the name "binomial formula" is often applied to the Taylor series for (1+x)^k, even when k is not an integer. You can even write it with binomial coefficients, if you take the generalized definition.
  • · Replies 16 ·
  • · Replies 105 ·
13K
