Open an MS access table by Visual Basic code
The discussion revolves around opening a password-protected MS Access table using Visual Basic code. Participants explore methods to automate the password entry process and address related security concerns. The conversation includes technical explanations, troubleshooting, and requests for further clarification.
  • Homework-related
  • Mike seeks assistance in opening a password-protected MS Access table using Visual Basic, noting that the program works without a password but fails with one.
  • One participant suggests using the OpenCurrentDatabase method with a password parameter, highlighting that the password is case-sensitive and discussing potential security vulnerabilities.
  • Mike requests further clarification on how to implement the suggested method in Visual Basic 6.0, indicating difficulties despite following the advice given.
  • Another participant provides a more detailed explanation of how to modify the OpenCurrentDatabase method call to include the password.
  • Mike expresses gratitude for the help but mentions a new issue regarding a security warning box that interrupts the program's operation, asking for further assistance on this matter.
  • A participant inquires about the nature of the warning box and its causes, seeking to understand the issue better.
Participants generally agree on the method to open a password-protected database, but there are unresolved issues regarding the security warning box and its implications. The discussion remains open with multiple perspectives on the security aspects involved.
Limitations include the potential for security vulnerabilities in the method discussed, as well as the lack of clarity regarding the specific causes of the security warning box that Mike encounters.
This discussion may be useful for developers working with Visual Basic and MS Access, particularly those dealing with database security and automation challenges.
Mike Phan
Hi,
I am writing a visual basic databse program, and need a code to open a MS access table which is protected by a password.
It can open the table without password. I need to protect it by password to prevent someone to open and edit it, but I have got a problem to let the visual basic open it by prompt the password automatically.
In short, if the table without password, everything works fine, and if the table is set by a password, the program cannot open that table so it displays an error message.
Please help. Thanks
Mike
Technology news on Phys.org
If an MS Access database is protected by a password, you can provide the password to the OpenCurrentDatabase method:
Code:
oAccess.OpenCurrentDatabase(filepath:="c:\myDatabase.mdb", _
                            Exclusive:=False, _
                            bstrPassword:="MyPassword")
A couple warnings.
Firstly, the password is case sensitive.
Secondly, a hacker could read the compiled binary executable and find your password. A simple private key would help, but not prevent.
Although if the database commands are streamed through a port, attempts to stop a hacker from seeing the password are futile. Unless, of course, MS Access uses a private/public key encryption, which I somewhat doubt.
This is all assuming that your password isn't worth only a few pretty pennies.
Sane,
Thank you for the help. Could you please explain liltle bit more about this method? How to add this to a Visual Basic 6.0 code?
I defined this function, and call it from the main form_load(). I changed the path to correct directory and change the password too. It still doesn't work. Sorry, I am not a programmer (EE)
Thanks a lot
Mike
It's quite straightforward, actually. First, find where the method "OpenCurrentDatabase" is being called. For instance, you might find this line somewhere in your code:
Code:
oAccess.OpenCurrentDatabase(filepath:="c:\myDatabase.mdb[/color]")
Then add an additional parameter, "bstrPassword", with a value equivilent to the password. The following code turns the above code into an example where the password is thisIsmyPassword[/color] ¹:
Code:
oAccess.OpenCurrentDatabase(filepath:="c:\myDatabase.mdb[/color]", bstrPassword="thisIsMyPassword[/color]")
If this doesn't answer your question, it would help to post your code.
¹ Red denotes a variable field.[/size]​
Mike Phan said:
Sane,
http://msdn.microsoft.com
msdn is an excellent resource once you know the name of a particular method. There is a full description of exactly what everything does and if you are lucky there are sometimes some quite useful examples.
The problem of course is finding the name of a method... luckily the tree view on the left will usually lead to some list of all of the methods that are a part of some library.
Unfortunately the amount and quality of the VB6 help seems to be lowering all of the time... if you need VB.net though it is extremely useful.
A search for your method's name reveals http://support.microsoft.com/kb/235422/ as the second result (the first: http://msdn2.microsoft.com/en-us/library/aa221388(office.11).aspx is the actual reference for the method).
Hope this helps.
Hi Jheriko,
Thank you very much. It is so cool. Now, my program is kind of opening a security Access database without prompt user password. However, I am still trying to DISABLE SECURITY WARNING BOX because it blocks the program. If you know about this, please help me some more. Thanks
Mike
Could you tell me more about this warning box? What is causing it to appear?
35K
12K
  • · Replies 16 ·
