Where is the 5.50 N force applied along the meter stick?
The discussion centers on a physics problem involving a meter stick pinned at one end, with two forces applied to achieve zero net torque. A force of 1.90 N is applied perpendicularly at the free end, while a 5.50 N force is applied at a 27-degree angle. The solution requires calculating the position along the stick where the 5.50 N force is applied to maintain equilibrium. The user successfully resolved the problem independently, indicating a clear understanding of torque and force application.
  • Understanding of torque and its calculation in physics
  • Knowledge of vector components and angles in force applications
  • Familiarity with equilibrium conditions in static systems
  • Basic proficiency in trigonometry for resolving forces
  • Study the principles of torque and rotational equilibrium in detail
  • Explore vector decomposition techniques for force analysis
  • Learn about the applications of static equilibrium in real-world scenarios
  • Practice problems involving multiple forces and angles to solidify understanding
Students in physics courses, educators teaching mechanics, and anyone interested in understanding the principles of torque and force equilibrium in static systems.
Adanne
One end of a meter stick is pinned to a table, so the stick can rotate freely in a plane parallel to the tabletop. Two forces, both parallel to the tabletop, are applied to the stick in such a way that the net torque is zero. One force has a magnitude of 1.90 N and is applied perpendicular to the length of the stick at the free end. The other force has a magnitude of 5.50 N and acts at a 27 degree angle with respect to the length of the stick. Where along the stick is the 5.50 N force apllied? Express this distance with respect to the end that is pinned.
Show your work so we can help you. Better yet, use the Homework Posting Template that you were provided.
sorry about that, but I figured out the problem on my own and the other question i had too.
  • · Replies 35 ·
  • · Replies 38 ·
