Thread Closed
Bose-Einstein Statistics
Share Thread Thread Tools
Dec13-06, 05:45 PM   #1
(a) Find the average energy per photon for photons in thermal equilibrium with a cavity at temperature T.
(b) Calculate the average photon energy in electron volts at T = 6000K.
2. Relevant equations
[tex] u(E)dE = \frac{8 \pi}{(hc)^3} \frac{E^3 dE}{e^{E/k_B T} - 1}[/tex]
3. The attempt at a solution
Integrate both sides of the equation.
[tex] \frac{E}{V} = \int_0^\infty u(E)dE = \int_0^\infty \frac{8 \pi}{(hc)^3} \frac{E^3 dE}{e^{E/k_B T} - 1}[/tex]
Use the fact that
[tex]\frac{z^3 dz}{e^z - 1} = \frac{\pi^4}{15}[/tex]
and that the equation can be rewritten as
[tex] \frac{8 \pi (k_{B}T)^3}{(hc)^3} \int_0^\infty \frac{ (\frac{E}{k_B T})^3 dE}{e^{E/k_B}-1} [/tex]
which finally gives
[tex] \frac{E}{V} = \frac{8 \pi (k_{B}T)^3}{(hc)^3} \frac{\pi^4}{15}[/tex]
Did I do this right?
Part b will be easy, just plug in the value for T if (a) is right.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec13-06, 06:35 PM   #2
Recognitions:
Homework Helper Homework Help
Ok, your approach so far is good, but you've missed three factors of kT (check your units!). Now you're asked to find the energy per photon, and you've found the total energy per volume, so you must now find the number of photons per volume and divide.
Dec13-06, 10:43 PM   #3
Whoops, must have missed translating the cubed into typing because it's on my paper.
Okay, so I should find N/V and divide. So for N/V
[tex]\frac{N}{V} = \int_0^\infty n(E)dE = \int_0^\infty g(E)f_BE(E)dE[/tex]
and after some algebra
[tex] \frac{N}{V} = \frac{8 \pi}{(hc)^3}(k_B)^2 \int_0^\infty \frac{z^2}{e^z - 1}[/tex]
where
[tex]z= \frac{E}{k_B T}[/tex]
and since
[tex]\int_0^\infty \frac{z^2}{e^z - 1} = 2.41[/tex]
the number per volume becomes
[tex]\frac{N}{V} = \frac{8 \pi}{(hc)^3}(k_B)^2 (2.41)[/tex]
after taking the energy per volume and dividing it by the number per volume
[tex] \frac{E}{N} = k_B T \frac{\pi^4}{15(2.41)}[/tex]
Dec13-06, 11:06 PM   #4
Recognitions:
Which is of course just what you would expect: kT times some number of order one. This is because the only energy scale in the problem is kT.
Dec14-06, 02:14 AM   #5
Recognitions:
THe average energy per photon is simply
[tex]\langle E\rangle =kT\frac{\zeta(4)\Gamma(4)}{\zeta(3)\Gamma(3)} [/tex]
Daniel.
Thread Closed
Thread Tools
Similar Threads for: Bose-Einstein Statistics
Thread Forum Replies
Fermi and Bose statistics... Quantum Physics 5
Bose-Einstein physics question Set Theory, Logic, Probability, Statistics 3
Canonical Bose-Einstein statistics Quantum Physics 3
Is there a proof for Fermi and Bose statistics? Quantum Physics 14
Gravity and Bose-Einstienian statistics Quantum Physics 0
