Thread Closed
Determining mass of isotope
Share Thread
Dec13-06, 07:25 PM   #1
One of the many isotopes used in cancer treatment is 19879Au, with a half-life of 2.70 d. Determine the mass of this isotope that is required to give an activity of 200 Ci.
2. Relevant equations
200Ci x 3.7x10^10 decays/s = 7.4 x 10^12 decays/s
T1/2 = ln2/lambda = 0.693/lambda
3. The attempt at a solution
I looked through my book in the section on half-life and radioactive dating, but could not find an equation(s) that would seem useful for this problem, since it involves mass (which is introduced later on in the chapter). The only equation I found relevant is the one I listed in (b). Any help would be appreciated. Thanks!
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Dec13-06, 09:49 PM   #2
Recognitions:
Homework Helper Homework Help
The fundamental principle underlying exponential decay is that activity is proportional to the number of atoms of a radioactive substance available to decay. Surely you have an equation of the form
A = A_o*exp{-kt}
and one of the form
A = k'N where N is the number of atoms in the sample.
How are k and k' related to half life?
Dec13-06, 11:07 PM   #3
Quote by OlderDan View Post
A = A_o*exp{-kt}
and one of the form
We don't have those equations in this book, but I see R=R_o_e^(-lambdat), and R=lambdaN. I'm assuming that your A is the same as my R, and your k is my lambda. If so, then I can say that lambda and lambda' is the decay constant, which gives the rate of decay in half-life.
I did some work while waiting for a response, so check if this is correct:
R=R_o_e^(-lambdat)
7.4x10^12 decays/s = (3.7x10^10 decays/s)e^(-lambda233280s)
200 = e^(-lambda233280s)
ln200 = -lambda233280s
lambda = 2.2712x10^-5 s^-1
R = lambdaN
7.4x10^12 decays/s = (2.2712x10^-5 s^-1)N
N = 3.2582x10^17 nuclei
Please let me know if I have done the correct steps up to this point. I do not know what to do next. Thanks.
Dec14-06, 08:10 AM   #4
The first equation you list is the equation for activity of a sample given some initial activity, and is commonly called the decay equation. To find the decay constant (lambda), you use the second equation since you already know the half life. The equation you don't have listed is that Activity of any given sample is the number of atoms in the sample times the decay constant. Since you now have the number of atoms, you can use Avogadro's number and the gram atomic weight to determine the mass.
Your lambda in this case is incorrect because lambda = ln2/half-life = .693/2.70 days = 0.000002971 per second. The way you set up your equation, you wrote that 200 curies = 1 curie*e(-lambda*half-life).
Dec14-06, 11:21 AM   #5
Recognitions:
Quote by FlipStyle1308 View Post
R=R_o_e^(-lambdat)
R = lambdaN
You are correct that your R is my A, and my constant is your λ. The 200 Ci activity has nothing to do with the calculation of λ from the given half life. daveb is correct on that point. But you do have the equation he says is missing in your quote above.
Dec14-06, 06:06 PM   #6
Okay, so here's my new work that I just did:
λ = ln2/T1/2 = 0.693/233280s = 2.9707x10^-6 decays/s
R = λN
200Ci x 3.7x10^10decays/s/Ci = (2.9707x10^-6decays/s)N
N = 2.491x10^18
(2.491x10^18)(6.022x10^23molecules/mol) = 1.5x10^42
I did not quite understand what you meant when I incorporate the gram atomic weight into this because it is not given. (The atomic mass in the book's appendix only lists that for 197_79_Au instead of 198_79_Au, which I need.
Dec14-06, 08:55 PM   #7
Recognitions:
R = λN
N = 2.491x10^18
http://chemlab.pc.maricopa.edu/periodic/Au.html
197.96822
Dec14-06, 08:59 PM   #8
Thanks. But I still don't know how to plug this into whatever equation I'm supposed to be using. Or is it...
(2.491x10^18)(6.022x10^23molecules/mol)(197.96822) = 2.9697 x 10^44?
Dec14-06, 09:49 PM   #9
Recognitions:
Your N should be the number of molecules, so you should be dividing by Avegadro's number to find the number of moles. The 197.96822 is molar mass, or grams per mole, so I believe you are looking for
(2.491x10^18molecules)(197.96822gm/mol)/(6.022x10^23molecules/mol)
Dec14-06, 09:58 PM   #10
So I should get an answer of 0.8189 mg?
Dec14-06, 10:01 PM   #11
Recognitions:
Again you want somebody to multiply for you?
Thread Closed
Similar discussions for: Determining mass of isotope
Thread Forum Replies
Calculating mass of an isotope Introductory Physics Homework 10
Determining the mass of a holder through a "Period Squared vs. Mass Added" graph? Introductory Physics Homework 5
Determining certain mass of a Hydrate Biology, Chemistry & Other Homework 2
One isotope of a metallic element has mass number 59 and 31 neutrons in the nucleus. Biology, Chemistry & Other Homework 1
Atomic mass: Isotope question Chemistry 3
