Urgent: Interfering Waves Homework: Find Speed in Regions A & B
  • Thread starter Thread starter kevykevy
    Urgent Waves
The discussion focuses on calculating the speed of water waves in two regions of a ripple tank, using a plane wave generator with a frequency of 60.0 Hz and a wavelength of 3.0 cm. The speed in region A is determined to be 3.14 m/s, while the speed in region B is calculated as 1.03 m/s. Snell's Law is applied to relate the speeds in both regions based on the angles of the wave crests, which are 25.0 degrees in region A and 14.0 degrees in region B. The calculations confirm the velocities derived from the wave properties.
  • Understanding of wave properties, including frequency and wavelength
  • Familiarity with Snell's Law in wave mechanics
  • Basic knowledge of trigonometric functions, specifically sine
  • Ability to perform unit conversions (e.g., cm to m)
  • Study Snell's Law applications in different media
  • Learn about wave speed calculations in various physical contexts
  • Explore the relationship between frequency, wavelength, and wave speed
  • Investigate the effects of boundary conditions on wave behavior
Students studying physics, particularly those focusing on wave mechanics, as well as educators looking for practical examples of wave speed calculations in different media.
kevykevy
A plane wave generator with a freqenecy of 60.0Hz creates a water wave of wavelength 3.0cm in region A of a ripple tank. The angle between the wave crests and straight boundary between regions A and B is 25.0 degrees in region A and 14.0 degrees in region B. Find the speed of the wave in each region.
f = 60.0Hz
lambda = 0.030 m
thedaA = 25.0 degrees
thedaB = 14.0 degrees
vA = ?
vB = ?
I was thinking to use snell's law, but I am not sure how to...
General v...
v = f x lamda
v = 60 x 0.030
v = 1.8 m/s
Find vA
vA/1.8 = Sin25/Sin14
vA = 3.14 m/s
Find vB
vB/1.8 = Sin14/Sin25
vB = 1.03 m/s
kevykevy said:
v = f x lamda
v = 60 x 0.030
v = 1.8 m/s
Yes, so this is already the velocity in region A.
vB = 1.03 m/s
This looks ok at first sight.
11K
