Is There Validity to the Controversial Anisotropic Speed of Light Paper?
The discussion centers around a controversial paper proposing an anisotropic speed of light, examining its experimental results and implications. Participants analyze the validity of the claims made in the paper, focusing on the methodology, data interpretation, and potential errors. The conversation includes technical reasoning and critiques, with an emphasis on the implications for physics and cosmology.
  • Some participants express skepticism about the paper's findings, suggesting that the results may be influenced by measurement errors or insufficient data.
  • Concerns are raised regarding the limited data set used in the analysis, with some noting that the authors based their conclusions on only four days of data.
  • Participants highlight the need for more sensitive instruments and longer data collection periods to validate the claims made in the paper.
  • Some argue that the authors' claims of detecting anisotropies in the speed of light due to Earth's rotation are questionable, suggesting that such signals might be indistinguishable from noise.
  • There is a discussion about the credibility of the paper, with some participants asserting that it lacks sufficient rigor and that previous experiments have ruled out similar claims.
  • Others note that a positive result regarding anisotropic speed of light would have significant implications for the field, but express doubt that such a result will be found.
Participants generally disagree on the validity of the paper's claims, with multiple competing views regarding the adequacy of the methodology and the interpretation of results. The discussion remains unresolved, with no consensus on the paper's credibility or implications.
Limitations include the reliance on a small data set, potential systematic errors in measurements, and the need for more comprehensive testing to substantiate claims of anisotropy.
This discussion may be of interest to those engaged in experimental physics, cosmology, and the study of relativity, particularly in relation to the ongoing debates about the speed of light and its implications.
Wallace
Anisotropic speed of light??
I hope this paper is appropriate to discuss here, as it demonstrates some interesting, if highly controversial, results. http://xxx.lanl.gov/abs/astro-ph/0608223"
If you are interested in learning about relativity, avoid this thread, if you are an expert I'd love you thoughts on this work.
Mods, if this is going to cloud the water here then lock away, but I'd be interested to see if anyone can spot any glaring errors in the analysis. As I see it this is an apparently valid experimental result. Intuitively I would think that if the effect they find is real then it would have been seen before, but then again I can't think of any direct tests published recently that have measured this to the precision that these guys report.
On the one hand cranks annoy me as much as anyone, on the other hand it erks me slightly that these kind of papers are generally ignored by the mainstream. I'm not implying this is due to some kind of conspiracy, rather I think people are too busy to bother, but I'd like to see some more attention paid to refuting these kind of claims that get submitted to astro-ph.
I would expect this paper does contain errors that invalidate the result, but I lack the skill to find any.
Wallace said:
...I'd be interested to see if anyone can spot any glaring errors in the analysis. As I see it this is an apparently valid experimental result.
Fig. 3 of the paper shows that what they are actually measuring is the time-averaged quantization error of their A/D converter, and Figs. 3-7 show that they are basing their analysis on only four day's worth of "data".
Mansouri & Sexl (their Ref. 1) describe several real experiments that constrain [tex]\alpha=-0.500 \pm 0.021[/tex] or better...compare that to the results reported in this paper of [tex]\alpha=-0.4106 \pm 0.0225[/tex].
It's even worse. They did not measure anything at all as long as their apparatus was fixed. They obtain a=-0.41 only when they rotate it, and then carefully neglect any systematical errors the rotation might induce.
Some people here (including Aether) still know that they claimed a few moths ago to have measured a=0 with essentially the same apparatus - and essentially the same confidence in their results.
I'm not sure I see any glaring errors unless you count the precision itself as a glaring error. The problems I see are related to the precision.
The authors restrict their search to two narrow 17deg windows around the passage of Leo across the local horizon. They claim the apparatus is only sensitive enough to detect anisotropies in these narrow windows. This in itself suggests the apparatus is inadequate and any separation of a signal from noise is problematic.
In fig 9 the error bars don't indicate a good fit to their model. Further they don't give the CL. Is it 1, 2, 3 or more sigma? I suspect the CL is 1 sigma as the only CL they report is quoted from COBE data. This suggests to me they are reporting results at a similar CL.
The COBE data [29] indicate a big temperature anisotropy in the cosmic background radiation shich is represented by a dipole form with an amplitude of T/T0 = 1.23 ×10−3 = 0.123%. This arises from the motion of the solar system barycenter, with a velocity v = 371 ±0.5kms−1( = 0.001237 ±0.000002) at 68%CL, relative to the so called “CMBR rest frame” and towards a point whose equatorial coordinates are ( , ) = (11.20 h 0.01 h , −7.22 0 ±0.08 0). This direction points to the Leo constellation.
While I don't claim any particular expertise in this area I do have considerable experience interperting data and the associated error and in my opinion the authors don't prove conclusively that this signal dependence on the Earth's movement is anything more than noise. I would respectfully suggest they need a more sensitive instrument and data over serveral 24hr periods with a better overall fit at a higher confidence level before republishing.
Good points Ich and paw.
Signals with a 24hr period are most likely due to thermal drift, so terrestrial experiments that try to constrain the Mansouri-Sexl parameters are often repeated many times over the course of one or more years in an attempt to detect a clear sidereal signature (e.g., a signal having a frequency of 366.25 cycles per year as opposed to 365.25 cycles per year).
I agree, but it does seem they are claiming to have detected anisotropies in c due to the Earths rotation. That's why I suggested several 24hr periods.
The sidereal signature should be much easier to detect. Unfortunately, there's probably no thermal drift that could be interperted as a variation in c.:biggrin:
You have to admit, a clearly positive result would definitely have an impact on physics and cosmology. Personally, though, I don't think we'll ever see that. I think any clear anisotropy would have been detected by now.
Yes, but this isn't a credible paper at all. Wallace said
When papers like this are submitted to a journal, then they will either get quietly shot down or they will get published. Perhaps the authors of papers that never get published should be expected to either withdraw the paper from arxiv.org, or at least to post the referee's criticism in an addendum to the paper?
We do know that the first-order anisotropy reported in the paper under discussion here has been ruled out by other experiments, but we do not really know what future experiments might find at ever-higher levels of precision.
  • · Replies 42 ·
  • · Replies 19 ·
  • · Replies 45 ·
  • · Replies 33 ·
  • · Replies 25 ·
  • · Replies 58 ·
