How do I find the moment of inertia for shapes with uniform density?
The discussion revolves around finding the moment of inertia for shapes with uniform density, specifically a rectangular sheet and a thin uniform disk. Participants explore the mathematical formulation and integration techniques required to derive these values.
  • Homework-related
  • One participant expresses uncertainty about how to find the moment of inertia, proposing an initial formula involving integration over area and questioning the limits of integration.
  • Another participant corrects the first by stating that the moment of inertia is given by the integral of density times the square of the distance from the origin, suggesting specific limits for integration based on the dimensions of the rectangle.
  • A third participant proposes a specific expression for the moment of inertia, but it is met with skepticism regarding its accuracy.
  • A subsequent reply challenges the accuracy of the proposed moment of inertia, asking for clarification on the calculations involved.
Participants do not reach a consensus on the correct moment of inertia values, with disagreements on the calculations and results presented. Multiple competing views remain regarding the correct approach and answers.
There are unresolved mathematical steps and assumptions regarding the integration process and the application of formulas for different shapes. The discussion reflects varying levels of understanding and confidence in the calculations.
Students and individuals seeking to understand the calculation of moment of inertia for various geometric shapes, particularly in the context of physics and engineering problems.
jlmac2001
I'm don't really know how to find the momemt of inertia. I have two questions that I'm stuck on.
Two questions:
1. Find the moment of inertia of a sheet f mass M and uniform density which is in the shape of a rectangle of sides a and b, for rotations about an axis passing through its center and perpendicular to the sheet.
answer:Will I start with this I= (integral over A)M/A dA? How would I find the limits of integration and integrate this?
2. Find the moment of inertia of a thin uniform disk of mass M and radius a for rotations about an axis through a diameter of the disk.
answer: Will th answer be I=2M/a^2 (a^4/4)=Ma^2/2?
1. that isn't the answer, no
I is the integral over A of pr^2 dA where p is the density and r is the distance from the origin
ie int over A of p(x^2+y^2)dxdy
the limits for x are -a/2 to a/2 and y is -b/2 to b/2
also use abp=M, I'm presuming you can do double integrals - this one is quite easy.
the second one is somewhat harder, but just try this for now.
is this right
M(a^2/48+b^2/48) is the moment of inertia
you're about a factor of 16 out, how did you get that? show your working...
