Momentum and acceleration due to gravity
The discussion revolves around concepts of momentum and the acceleration due to gravity, particularly in the context of how these concepts relate to the danger posed by moving objects and the effects of changing the radius in gravitational equations.
  • Participants explore the relationship between momentum and danger, questioning whether the object with greater or lesser momentum is more hazardous. They also discuss the implications of doubling the radius on the acceleration due to gravity and the appropriate equations to use.
Participants are actively engaging with the concepts, with some clarifying the distinction between gravitational force and acceleration due to gravity. There is a recognition that doubling the radius affects the value of g, with suggestions on how to express this mathematically.
There is some confusion regarding the definitions and relationships between gravitational force and acceleration due to gravity, as well as the implications of changing the radius in gravitational calculations.
pharaoh
what object is dangerous for the target, the one that has greatest momentum or the one that has least momentum and why? what is safest?
I answeres all the parts that contain momentum and velocity and force but i stucked in this one
also
what is the value of g (acceleration due to gravity) if the radius doubled?
is the right formula for this question is Fg= G m1m2/r^2, or do i have to substitute the Fg with m*a, then do the rest
Things with momentum are dangerous because it means they're moving. Are you more scared of a knife on a table or a knife thrown at you?
That equation you posted is correct. Everything should factor out leaving 1/(r^2). How does the gravity change when the r in 1/(r^2) is changed from 1 to 2, or from 2 to 4?
so you mean that Fg is the same as g right
and the object that has greatest momentum is the most dangerous
if i doubled the radius then the g= 1/4
No, Fg is not the same as g. From the equation, F=(Gm1m2)/r^2 which gives m2g=(Gm1m2)/r^2 and so g=Gm1/r^2
Correct
Right idea: the new value of g obtained when doubling the radius will be 1/4 times the old value of g. So, write [itex]g_{new}=\frac{1}{4}g[/itex]
  • · Replies 24 ·
  • · Replies 25 ·
