Displacement and average velocity
The problem involves a hiker's journey with two segments of travel, focusing on calculating displacement based on average velocities and time traveled. The subject area pertains to kinematics, specifically displacement and average velocity.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of displacement using average velocity and time, with some questioning the accuracy of the initial problem statement. There are attempts to clarify the relationship between distance, velocity, and time, as well as the need to perform separate calculations for each segment of the trip.
The discussion is active, with participants providing guidance on the approach to calculating total distance and addressing unit consistency. There is recognition of the need to clarify the calculations for each segment of the journey, but no consensus has been reached on the final answer.
Participants note potential confusion regarding the interpretation of time in hours and the need for consistent units throughout the calculations. There is also mention of a review sheet provided by the teacher, which may impose certain constraints on how the problem is approached.
JMWM
A hiker travels south a long a straight path for 1.5 h with an average velocity of .75 km/h. then travels south for 2.5 h with an average velocity of .90 km/h. What is the hiker's displacement for the total trip?
For the answer I have 3.4 km to the south.
but hm, I think I copied the question wrong. I have a feeling that I was supposed to have another coordinate sign besides south... so I'm not sure.
Well, your answer is correct (3.375 km i get before rounding) if the question is as you've written it!
oh ok. cool.
but oh gosh, let me try it. but well I'm not really sure what to do.
Ahh, so you mean that's the answer the book gives? Ok, well what equation do you know relating velocity, distance and time?
well its a review sheet, the teacher gave it to me.
distance/t
or do I use: av. velocity= total distance/time
Yes, use av.velocity=distance/time, but remember to calculate the two parts separately, and then add them up at the end to arrive at a total distance.
awesome.
another question, for instance 1.5 h, ok do I convert that into minutes? and if so do I take the .5 as half or as 50, as in fifty minutes. 1 hour and fifty minutes or 1 and a half or 90 minutes or 110 minutes?
wow, I ask a lot of questions.
Well, you would take 1.5h as one and a half hours, or 1 hr 30 mins. However, in this instance, you don't need to convert.
The units of velocity are given as km/hr, and the times in hr, so, if we look at the equation: s=vt, and consider putting the units in, we get s (km) = v(km/hr)*t(hr). Notice that the hr's will cancel, and give a result in km, which is what is required.
For calculations like this, as long as you keep to the same units throughout, the answer will be correct. (A problem would occur if, for example, the velocity was in km/hr and the time measured in seconds. In this case we would have to convert units)
Hope this is clear!
yeah that's what I noticed.
but well ok for km/h I get 1.65 and then for hours 4.
so this is my equation: 1.65 km/h /4h and then I get .4125...
eek. I know I'm doing something wrong.
Re-read post #6. You need to do one calculation to work out the distance for the first part: traveling along a straight path for 1.5 h with an average velocity of .75 km/h, and another calculation for the second part: traveling for 2.5 h with an average velocity of .90 km/h.
When you have these two distances, add them up and you will get the required answer.
ooops, sorry. got you. thanks!
  • · Replies 18 ·
