How Can You Calculate Heat Transfer and Energy Costs in Various Scenarios?
This discussion focuses on calculating heat transfer and energy costs in various scenarios using specific equations. For the electric oven problem, the correct equation is Q = (KAΔT)t/L, yielding an energy usage of approximately 2,104,769.76 J and a cost of about $0.05 for 1.28 hours of operation. The second problem involves calculating the temperature difference between blood capillaries and skin using the same equation, resulting in a ΔT of approximately 20.83 °C. The discussion also addresses the heat loss ratio between wool and goose down jackets, emphasizing the use of thermal conductivity values in calculations.
  • Understanding of heat transfer equations, specifically Q = (KAΔT)t/L
  • Knowledge of thermal conductivity values for different materials
  • Basic principles of energy cost calculations in electrical systems
  • Familiarity with temperature measurement in Celsius and conversion to Kelvin
  • Research thermal conductivity values for various materials, including body fat and goose down
  • Learn about energy cost calculations using formulas for power and time
  • Explore advanced heat transfer concepts, such as convection and radiation
  • Study the Stefan-Boltzmann law for calculating radiative heat transfer
Students in physics or engineering courses, professionals in thermal management, and anyone involved in energy efficiency calculations will benefit from this discussion.
moonlit
I have some homework problems that I've been stuck on. Not sure if someone can point me in the right direction...
1) The temperature in an electric oven is 173 °C. The temperature at the outer surface in the kitchen is 39.8 °C. The oven (surface area = 1.51 m^2) is insulated with material that has a thickness of 0.0258 m and a thermal conductivity of 0.03 J/(s m C°). (a) How much energy is used to operate the oven for 1.28 hours? (b) At a price of $0.10 per kilowatt-hour for electrical energy, what is the cost (in dollars) of operating the oven?
I was going to use the equation Q/t=AK delta T/L for the first part but now that I think about it, I think that's the wrong equation to use...
2) The amount of heat per second conducted from the blood capillaries beneath the skin to the surface is 200 J/s. The energy is transferred a distance of 2.4 x 10^-3 m through a body whose surface area is 1.9 m^2. Assuming that the thermal conductivity is that of body fat, determine the temperature difference between the capillaries and the surface of the skin.
I tried using the equation Q=(KA delta T)t/L but once again I think this is wrong
3)A skier wears a jacket filled with goose down that is 15.5 mm thick. Another skier wears a wool sweater that is 7.13 mm thick. Both have the same surface area. Assuming the temperature difference between the inner and outer surfaces of each garment is the same, calculate the ratio of heat lost through wool to heat lost through goose down during the same time interval.
Not even sure what equation to use on this one
4) A car parked in the sun absorbs energy at a rate of 717 watts per square meter of surface area. The car reaches a temperature at which it radiates energy at this same rate. Treating the car as a perfect radiator (e = 1), find the temperature in Kelvin.
I tried to solve this problem using the equation Q/tA=e(5.67x10^-8)(T^4) but I can't get the right answer. Can someone please explain this one step by step. Thanks!
Hi there,
For the first problem, you are correct in using the equation Q = (KAΔT)t/L. To find the energy used to operate the oven for 1.28 hours, we need to first calculate the temperature difference between the inner and outer surfaces of the oven. This can be done by subtracting the outer temperature (39.8 °C) from the inner temperature (173 °C), giving us a ΔT of 133.2 °C. Now, we can plug in the given values into the equation:
Q = (0.03 J/(s m °C)) * (1.51 m^2) * (133.2 °C) * (1.28 hours * 3600 seconds/hour) / (0.0258 m)
This gives us an energy of about 2,104,769.76 J. To find the cost of operating the oven, we can use the formula Cost = (Power * Time * Cost per kWh) / 1000. In this case, the power is given by the energy used (2,104,769.76 J) divided by the time (1.28 hours * 3600 seconds/hour), giving us a power of 490.38 W. Plugging this into the formula, we get a cost of about $0.05.
For the second problem, the equation you are looking for is Q = (KAΔT)/L. Here, we are given the heat conducted per second (200 J/s), the distance (2.4 x 10^-3 m), and the surface area (1.9 m^2). The thermal conductivity of body fat can be found online to be around 0.2 J/(s m °C). Plugging in these values, we get:
200 = (0.2 * 1.9 * ΔT) / (2.4 x 10^-3)
Solving for ΔT, we get a temperature difference of about 20.83 °C.
For the third problem, we can use the equation Q/t = (KAΔT)/L, similar to the first problem. Here, we are trying to find the ratio of heat lost through wool to heat lost through goose down. We can set up two equations, one for each garment, and then divide them to find the ratio. For the wool sweater, we have:
Q1/t
