| Thread Closed |
Gravitational Constant |
Share Thread | Thread Tools |
| Dec20-06, 02:20 PM | #1 |
I'm writing a report about the gravitational constant G. I have trouble figuering out what all the variables mean means. G = w^2 * r^2 * d(Φ1 - Φ2) / 2M(1 + d/r(Φ1 - Φ2)) The experiment was executed in Cavendish torsion balance. Two wires which held 2 large orbs, and 2 small orbs, had an laser with a lens attached. Since all masses attract, oscillation the oscillation was shown on a screen. Then you could measure the movement and the change in angles. 2. Relevant equations G = w^2 * r^2 * d(Φ1 - Φ2) / 2M(1 + d/r(Φ1 - Φ2)) Angle = arctan(W all)/D))/2 Divide by two because of the lens. Y1=Φ1 + A *sin(wt +d1) Y2=Φ2 + A *sin(wt+d2) 3. The attempt at a solution I believe W is the frequency, d is the distance of the short wire with the two small orbs, M is the mass of both? orbs, Φ1 & Φ2 are the angles and r is the radius. If you guys could verify this and please correct me if I'm wrong. If anything is unclear please say so, since I'm not too good at english. Thank you! |
| Dec20-06, 02:50 PM | #2 |
I note that the "w" is probably "omega" (an ANGULAR frequency).
| Thread Closed |
| Thread Tools | |
Similar Threads for: Gravitational Constant
| Gravitational constant | Introductory Physics Homework | 1 | ||
| Gravitational constant | General Discussion | 12 | ||
| Gravitational constant | Classical Physics | 6 | ||
| gravitational constanT G -- HELP! | General Astronomy | 1 | ||
| The Gravitational Constant | General Physics | 1 | ||
