How Does Radiation Trigger Genetic Mutations?
  • Thread starter Thread starter Andrew Mason
    Mutation Radiation
The discussion revolves around the mechanisms by which radiation triggers genetic mutations, focusing on the types of radiation (ionizing vs. non-ionizing) and their effects on DNA. Participants explore both direct and indirect effects of radiation on genetic material, as well as the biological processes involved in mutation and DNA repair mechanisms.
  • Some participants propose that radiation cannot directly cause genetic mutations but may trigger biological processes that lead to mutations.
  • Others argue that ionizing radiation can directly damage DNA, causing single or double strand breaks, which can lead to mutations during repair processes.
  • One participant questions whether a mutation requires a specific rearrangement of nucleic acids and whether a damaged DNA molecule is sufficient for mutations to be passed on.
  • Another participant provides detailed statistics on the types of DNA damage caused by radiation and describes various DNA repair mechanisms, suggesting that errors during these processes can lead to mutations.
  • Some participants emphasize that not all natural mutations are repaired, and that external radiation can accelerate the accumulation of mutations, potentially leading to cancer.
  • There is mention of the hormetic effect, where radiation might stimulate cellular repair mechanisms or the immune system, though the exact mechanisms remain unclear.
Participants express differing views on whether radiation alone can cause genetic mutations, with some asserting that it can while others maintain that biological processes are necessary for mutations to occur. The discussion remains unresolved regarding the specific mechanisms and implications of radiation-induced mutations.
Participants note the complexity of DNA repair mechanisms and the potential for errors during these processes, highlighting the uncertainty surrounding the relationship between radiation exposure and genetic mutation. The discussion also touches on the concept of radiation hormesis, which lacks extensive research.
Andrew Mason
There is a general belief that radiation can cause genetic mutation. I have never understood the mechanism by which such mutation could result.
An alpha particle (+helium nucleus), beta particle (-electron) or a gamma ray (high energy em radiation with a wavelength smaller than an atomic diameter) whizzing through a strand of DNA could obviously break some chemical bonds and knock out some atoms. But it is not going to substitute one nucleic acid (each with a molecular weight of about 500) for another and change the genetic code. The effect will be a random rearrangement of some of the constitutent atoms, not a change in the genetic code.
I conclude that radiation alone cannot physically cause genetic mutation. If it causes mutation it must do so by triggering some biological process that results in mutation. So what is the biological mechanism by which radiation is supposed to cause genetic mutation?
AM
Biology news on Phys.org
It is ionizing radiation that is dangerous, as you say it can break chemical bonds and knock out electrons out of their orbits, or neutrons can physically collide with an atom.
Ionizing radiation can have a direct effect on DNA, by causing single or double strand breaks, or it can have an indirect effect when free radicals (produced by the ionizing radiation) attack and modify the bases.
That is a perfectly good explanation of how radiation can cause DNA damage. But my question is: how does it cause genetic mutation? Does a mutation not require some rearrangment of the ACGT sequence of nucleic acids in the DNA molecule - and doesn't the mutation have to occur exactly the same way on both strands? Is a damaged DNA molecule all that is needed to cause a mutation that can be passed on to successive generations?
Ionizing radiation can knock off some hydrogen atoms or perhaps (by neutron capture) induce atomic nuclei to become radioactive and decay. But the probability that radiation can rearrange DNA by itself has to be virtually nil. It has been my impression that the information redundancy within the DNA molecule and the ease with which DNA damage can be detected within the cell (ie. loss of double helix structure) are important reasons that DNA has evolved as the basis for all cellular life.
AM
See these links:
http://taylorandfrancis.metapress.c...,247,535;linkingpublicationresults,1:100668,1
http://mcb.asm.org/cgi/content/abstract/14/3/1901
http://www.rerf.or.jp/eigo/radefx/basickno/radcell.htm
http://en.wikipedia.org/wiki/DNA_repair
http://enhs.umn.edu/hazards/hazardssite/radon/radonmolaction.html
Also, not all natural mutations of DNA are repaired--most but not all. Over time these mutations add up, can cause problems with cell division (cancer). External radiation can only quicken this process. Clearly, radiation alone does cause genetic mutation, the experimental evidence is conclusive. Do not confuse this fact with arguments of radiation hormesis (helpful aspects of radiation)--see these:
http://interactive.snm.org/docs/Radiation_Hormesis_JNMT_March_O3.pdf
http://interactive.snm.org/index.cfm?PageID=5159&RPID=10
I can explain it further, let me first clarify some more how often you can expect a certain DNA damage per Gy (taken from lecture notes of the Netherlands Cancer Institutes):
30 interstrand crosslinks
40 double strand breaks (most lethal type of damage)
150 DNA-protein crosslinks
500-1000 single strand breaks
1000-2000 base damages
* Base damage (oxidized, methylated, missing bases) and single strand breaks are repaired by the base excition repair pathway, that takes out damaged bases and fills in the the gap by matching the bases with the complementary strand.
* Double strand breaks are repaired by homologous recombination, non-homologous end-joining (most common) and single strand annealing.
* Crosslinks (pyrimidine dimers, protein adducts) are repaired by nucleotide excision repair and homologous recombination.
* Mismatched bases are repaired by mismatch repair.
So how does a DNA break or base damage cause genetic mutation, especially with all the repair mechanisms in place.
Sometimes a base is modified in such a way that it looks a lot like another base. During DNA replication the DNA polymerase will integrate the wrong base and so a mutation is fixed.
DNA breaks are not clean, there are usually several nucleotides damaged. Repair can go faulty. Also, non-homologous recombination is a quick-fix for repairing double-strand breaks, but often deletions or additions occur. Homologous recombination is much more accurate, but it is a slow process since the damaged DNA needs to find its homolog.
So radiation does not rearrange DNA, but it damages it in such a way that during repair or replication wrong bases are put in.
Thank-you for a very helpful reply. I will feed on that for a while and see where it takes me.:rolleyes:
AM
Rade said:
See these links:
Thanks for the links, which I have read now.
I have another thread on Hormesis https://www.physicsforums.com/showthread.php?t=148847"
It is the hormetic effect that intrigues me. The cell repair mechanisms may be stimulated by being 'exercised' by having to repair radiation damage. There doesn't seem to be a lot of research on the actual mechanism by which this might occur.
Alternatively, it occurs to me that radiation may stimulate the immune system to detect and remove damaged cells that the cell repair mechanisms cannot fix. It is not clear (to me at any rate) what the hormetic effect results from.
AM
15K
