Centre of mass of a solid cone
The discussion revolves around determining the center of mass of a solid cone. Participants are exploring the mathematical representation and derivation involved in finding the centroid coordinates of the cone.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants are attempting to understand the geometric representation of points within the cone and how to derive the centroid coordinates. Some are questioning the derivation process and seeking clarification on the use of diagrams and mathematical expressions.
There are various approaches being discussed, including the representation of points in the cone and the computation of the Jacobian for integration. Some participants have provided guidance on the mathematical relationships needed to derive the centroid coordinates, while others are expressing difficulty in understanding the derivation.
Some participants have noted the challenge of the derivation and the need for visual aids, indicating that the problem may involve complex mathematical concepts that require careful interpretation.
shreyaacharya
im actually bugged of finding a solution for d topic mentioned can any 1 pleasezzz help me
pleasezz help me solve dis problem
Do not post homework problems in the tutorials section!
Now, to help you along a bit, let I be the cone's base in the plane z=0, and let (X,Y) denote a point in I. Let the vertex have the coordinates: [itex]\vec{r}_{v}=(x_{v},y_{v},z_{v})[/itex].
Thus, any point within the cone will lie on some line segment from [itex]\vec{r}_{v}[/itex] to a point (X,Y) in I, so we can therefore represent all points in the cone with the following function:
[tex]\vec{r}(X,Y,u)=(\vec{r}_{v}-(X,Y,0))u+(X,Y,0), 0\leq{u}\leq{1},(X,Y)\in{I}[/tex]
[tex]\vec{r}(X,Y,u)\equiv(x(X,Y,u),y(X,Y,u),z(X,Y,u))[/tex]
This should be useful to you.
In particular, remember that the x-coordinate to any given point in the cone is:
[tex]x(X,Y,u)=(x_{v}-X)u+X[/itex]<br /> and similar expressions for the y-and z-coordinates to anyone point in the cone.[/tex]
Search under my name and using the keyword "cone". I've gone through the entire derivation in an earlier discussion in the HW forum.
this waz a very difficult derivation ...can u be kind enough o explain wid a diagram...thank u
Now, remember that the centroid coordinates are gained by averaging the point coordinates over the volume V of the object O.
For example, the horizontal centroid coordinate [itex]\hat{x}[/itex] is given by:
[tex]\hat{x}=\frac{\int_{O}xdV}{\int_{O}dV}=\frac{\int_{O}xdV}{V}, dV=dxdydz[/tex]
Now, just compute the Jacobian to the cone representation I've given, so that you may integrate with respect to the variables (X,Y,u) instead.
Since it is Yule, I'll be a bit more charitable:
1. The Jacobian is readily computed to be [itex](1-u)^{2}z_{v}[/tex]<br /> 2. We also have the coordinate representations:<br /> [tex]x(X,Y,u)=(x_{v}-X)u+X,y(X,Y,u)=(y_{v}-Y)u+Y, z(X,Y,u)=z_{v}u[/tex]<br /> <br /> Use these relations to derive the coordinates for the centroid![/itex]
  • · Replies 35 ·
  • · Replies 16 ·
