Is There a Programmable Oscillator Chip for Low MHz Range?
  • Thread starter Thread starter Jdo300
    Oscillator
The discussion centers around the search for a programmable oscillator chip suitable for low MHz applications, specifically up to 50MHz. Participants explore options for building or sourcing such devices for experimental purposes, considering budget and technical requirements.
  • Homework-related
  • Jason O inquires about the existence of a programmable oscillator chip for low MHz frequencies, expressing a desire to avoid expensive frequency generators.
  • One participant notes that while programmable oscillator chips are common, they often have a limited number of preset frequencies and may require additional components for continuous frequency variation.
  • A suggestion is made to check manufacturers like Analog Devices and Texas Instruments for suitable products, although a specific example is provided that only reaches 20kHz.
  • Another participant proposes building a programmable oscillator using a Wien Bridge topology, asking about Jason's budget, time constraints, and specific requirements for frequency stability and distortion.
  • Jason O responds with details about needing three oscillators, emphasizing the importance of frequency stability and low distortion for triggering a DS1040 IC.
  • Jason O expresses interest in simpler solutions, asking for recommendations on kits for building a pulse generator with adjustable duty cycle, ideally capable of reaching around 1MHz.
  • A participant provides a link to a search for electronic kit pulse generators, suggesting that Jason O explore those options.
Participants do not reach a consensus on the availability of a suitable programmable oscillator chip for the specified frequency range. Multiple views are presented regarding the feasibility of existing products and alternative solutions, indicating an unresolved discussion.
Participants express varying requirements for frequency stability, distortion, and budget constraints, which may influence the suitability of suggested solutions. The discussion includes references to specific products and manufacturers but does not confirm their applicability to Jason O's needs.
This discussion may be useful for individuals interested in building or sourcing programmable oscillators for low-frequency applications, particularly in experimental or hobbyist contexts.
Jdo300
Hello All,
I'm wondering if there is such a thing as a programmable oscillator chip that I could use for my experiments. I want to work in the low MHz range (up to about 50MHz) but can't afford to buy a fancy frequency generator to accomplish the task; so, I got an old Motorola microcontroller and I want to see if I can use it to programmatically set the frequency for the oscillator. Does such a device exist?
Thanks,
Jason O
I know that programmable oscillator chips are quite standard, but:
1. They typically come with some number (like 5) of preset frequencies, and if you want to continuously vary the frequency, you have to throw in a trimpot or some such extension.
2. I've not seen a programmable oscillator that goes up to the MHz range - that is not to say that they don't exist.
Have you looked up Analog Devices, Linear Technologies, Texas Instruments and other usual suspects?
http://www.analog.com/UploadedFiles/Data_Sheets/AD2S99.pdf
That one goes up only to 20kHz, comes with 4 presets and allows you to add to it if you want more frequencies.
Alternatively, you could build yourself a programmable oscillator based on a standard Wien Bridge topology. What's the budget and time restrictions on this? Also, what are your requirements on amplitude and frequency stability, and harmonic distortion?
Hi Goku,
Thanks for the suggestions. As for my requirements and time constraints. I need to build three of these oscillators to do my tests and I am working on this in my free time so no huge time constraints there. As for the budget, I'm definitely not rich but it would be nice to keep the cost to a minimum. However, the oscillator needs to be very frequency stable and have low distortion. I will ultimately be using it to trigger a DS1040 IC to control some MOSFETS. So the oscillator can be a square wave one. I do need to have a wide range of frequency control on this one. I have been trying to think about how to do this digitally. Maybe using a digital resistor or something if I used some sort of analog version? Not sure.
Thanks,
Jason O
Hi Again,
I'm thinking I might go for something a bit simpler for the moment so I thought i'd ask if anyone knows of any good, cheap, kits to build a pulse generator with an adjustable duty cycle. Ideally, it would be nice if I could make one that could up to about 1MHz but I'm not too picky about that. Any suggestions?
Thanks,
Jason O
16K
10K
