Solving a Monatomic Gas Cooling Problem
  • Thread starter Thread starter rgo
    Cooling Gas
The problem involves calculating the number of moles of a monatomic gas that is cooled by 50°C at constant volume after removing 830 J of energy. The relevant equations include the First Law of Thermodynamics, where dQ = dU since dW = 0 at constant volume. For monatomic gases, the molar specific heat at constant volume (Cv) is defined as 3/2 R, allowing for the calculation of moles (n) using the equation dU = nCv(dT). This approach effectively utilizes the principles of thermodynamics and the properties of monatomic gases.
  • Understanding of the First Law of Thermodynamics
  • Knowledge of specific heat capacities, particularly for monatomic gases
  • Familiarity with the ideal gas constant (R)
  • Basic algebra for solving equations
  • Study the First Law of Thermodynamics in detail
  • Learn about specific heat capacities for different types of gases
  • Explore the concept of equipartition of energy in thermodynamics
  • Practice solving thermodynamic problems involving energy transfer
This discussion is beneficial for students studying thermodynamics, particularly those tackling problems involving monatomic gases and energy transfer in closed systems.
rgo
I really have no Idea where to start... Please help
A monatomic gas is cooled by 50 C at constant volume by removing 830 J of energy. How many moles of the gas is in the sample.
?Q=mc (delta)T
I am not sure where to start...a monatomic gas could be any of the noble gases, right? each with a different molecular weight and each would have a different specific heat at a constant volume(c). Is this even the right equation to start with. Thanks.
The main principle in this question is the First law of Thermodynamics
By 1st Law, dQ=dW+dU (using d for delta,nevertheless)
dW=0 as volume is constant
So, dQ=dU
Now, for monoatomic gases, Molar specific heat at constant volume is given by 3/2.R,where R=gas const.
as dU=nCdT, the values can be substituted to get the only unknown n, which is the no.of moles.
(Monoatomic is explicitly mentioned so that the Cv of the gas can be found out based on equipartition of energy)
Thanks
Thank you... That was perfect. It is frustrating because the formulas you used were never taught to me. They are in the book but they are outside the material we were required to learn. But my teacher is like that... Any how thanks for your help.
  • · Replies 67 ·
24K
