Solving Modular Multiplication with C/C++
  • Context: C/C++
  • Thread starter Thread starter chesschi
    Multiplication
The discussion revolves around implementing modular multiplication of large integers in C/C++, specifically the expression "a * b mod c" where a, b, and c are 64-bit integers. Participants explore various algorithms and techniques to handle potential overflow issues arising from the multiplication of large numbers.
  • One participant seeks an efficient algorithm for "a * b mod c" without using libraries like BigInt or gmp.
  • Another participant questions the use of the modulo operator and suggests using bitwise operations for specific cases, particularly when c is a power of 2.
  • Some participants propose using Montgomery multiplication or a divide and conquer division algorithm to manage the overflow from the multiplication of 64-bit integers.
  • Concerns are raised about the inability to guarantee a solution for all inputs due to potential overflow when c is arbitrary.
  • One participant discusses the mathematical properties of modular arithmetic and how they relate to overflow issues.
  • A code snippet is provided that attempts to implement modular multiplication but acknowledges potential pitfalls with integer wrapping and assumptions about bit sizes.
  • Several participants express uncertainty about the correctness of their approaches and the complexity of implementing a reliable solution.
Participants express a range of views on the best approach to modular multiplication, with no consensus reached on a single method. There are disagreements regarding the feasibility of certain techniques and the implications of using arbitrary values for c.
Participants note limitations related to integer overflow, assumptions about the sizes of integers, and the potential complexity of implementing certain algorithms without external libraries.
This discussion may be of interest to programmers working with low-level arithmetic in C/C++, particularly those dealing with cryptography or numerical methods requiring efficient handling of large integers.
chesschi
I want to write a C/C++ program and encounter a problem.If I have three 64 bit numbers and need to manipulate
"a * b mod c"
Is there any well-known, efficient and simple algorithm to implement it?
I only know it can be calculated sth. like this..
__int64 a, b, c
a = x1 * 2^32 + x0
b = y1 * 2^32 + y0
then a * b = x1y1 * 2^64 + (x0y1 + x1y0) * 2^32 + x0y0
but I don't know what to do in the next step
Note that this cannot be calculated using some classes like BigInt, gmp
Thank you very much!
Technology news on Phys.org
Sounds like an interesting question. My C++ experience is limited. Sorry I cannot offer much help there. However, I think you will have much better luck (more software folks) posting this in our programming subforum. If you wish to do this, just ask any moderator or mentor for assistance. In fact there are a couple of excellent C++ tutorials in that subforum.
Is c an arbitrary integer?
Does "a*b mod c" mean (a*b) mod c?
Also, what's with x0, x1, etc? Are you trying to do this with 32 bit integers instead of using 64 bit integers?
For the mod c, how about bitwise and with c? At least that should work if a, b, c >= 0. Edit: er, ok, maybe only if c is a power of 2. Edit 2: What's wrong with the modulo operator "%"? Forgot that was there...I usually use powers of two, where the & (c-1) trick works.
Cheers,
Tim
"a * b mod c"
__int64 a, b, c
a = x1 * 2^32 + x0
b = y1 * 2^32 + y0
Er, gmp does allow you to compute such things.
Anyways, I presume you're either going to have to do a Montgomery multiply, or you're going to have to use a divide & conquer division algorithm. (which will require splitting c into a high and low word).
a, b and c both are 64 bit integers, c is arbitary number, may not be in power of 2.
but a * b will generate a 128 bit intermediate integers which will overflow. So I believe there is an algorithm to deal with such problem
a = x1 * 2^32 + x0
b = y1 * 2^32 + y0
I'm not sure if this is correct...I just read some websites talking about it but they didn't provide details implementation. a and b are 64-bit integers, it tries to represent a,b in the power of 2 ^ 32 with the corresponding x1, x0, y1, y0 coefficients If there is any good suggestion other than this method, I'm also interested to know it!
For the montgomery multiply, the output is o = ab R^(-1) mod c, where R = 2^64...if you need to recover it...you still need to manipulate o * R mod c...
It seems it cannot solve in this case because o, R and c are still 64-bit integers
I am probably missing something enormous, but what is wrong with the '%' operator?
At worst you can use the 64-bit CPU instruction with an __asm block... (I am assuming you are using windows with your highly MS-specific __int64)
Jheriko, the (a*b) will overflow for large numbers.
I should have read the thread more, and actually thought before answering. Sorry for that.
As for splitting the multiplication it has almost been done above:
"a * b = x1y1 * 2^64 + (x0y1 + x1y0) * 2^32 + x0y0"
The key is to realize that the xi, yi are all 32-bit integers (although we store them in 64-bits) and so their products are 64 bits. We can jiggle the bits around to make the correct answer in two 64-bit integers.
__int64 upper = x1*y1 + ((x0y1 + x1y0) >> 32);
__int64 lower = x0*y0 + ((x0y1 + x1y0) << 32);
This should work as far as I can see... you can then use the existing 64-bit modulus operator.
Apologies for the necromancy, but this is just the problem I was working on.
Include
#define llong __uint64
or
#define llong unsigned long long
or whatever your system requires.
Code:
const llong LOW_MASK = 0xFFFFFFFF;
llong mod_mult (llong a, llong b, llong modulus) {
	// Compute a * b = 2^64 * upper + lower
	llong a1 = a & LOW_MASK;
	llong a2 = a << 32;
	llong b1 = b & LOW_MASK;
	llong b2 = b << 32;
	llong tmp = a1 * b2 + a2 * b1;	// (1)
	llong upper = a1 * b1 + tmp >> 32;
	llong lower = a2 * b2 + (tmp << 32);
	// Reduce mod modulus
	lower %= modulus;
	tmp = (0 - modulus) % modulus;	// tmp = 2^64 % modulus
	lower += upper * tmp;	// (2)
	return lower % modulus;
The 'obvious' code here has a number of problems, aside from the potentially non-portable use of integer wrapping and the assumption that llong is exactly 64 bits.
First, the assignment (1) could be as large as 2^65 - 3^34 + 2 which will cause upper to be off by 1. Second, the multiplication in (2) could be huge, almost as large as 2^128 -- and solving this problem is in essence no different from solving the original problem. So the naive method suggested above doesn't seem to work. Remarks?
CRG: are you familiar with Montgomery multiplication, Barrett reduction, and/or Newton division?
You could even go so far as to write a multiprecision division algorithm to compute the remainder.
KTC said:
You cannot write a general method that will guarantee to work for all possible input of a, b, c if you want the calculation to return a 64-bits value. "c is arbitary number" means that c can be 1, so unless you can guarantee (a * b) does not overflow, there is no possible solution. Of course, if you can guarantee (or assume) that (a * b) does not overflow, then the solution is trivial.
This makes no sense to me at all.
Maybe I'm suffering from brain fade here thinking back on my finite field days and ecc, but isn't the following true (assuming integer math here):
(a x b) mod c = ((a mod c ) x (b mod c )) mod c
(a + b) mod c = ((a mod c ) + (b mod c )) mod c
(a - b) mod c = ((a mod c) - (b mod c)) mod c
a mod c = (a - (n x c)) mod c
If c < 2^32, there's no overflow issue.
If c >= 2^32, then there's an issue with potential overflow.
This would all be so easy in 64 bit mode assembly where there is a 128 product and 128 bit dividend to work with.
Anyway, to divide 128 bit number by a 64 bit number in 3 steps:
normalize both numbers (left shift until most significant bit is 1), keeping track of shift counts.
Divide normalized a x b by normalized c.
Shift the quotient right by the appropriate bit count.
Subtract 1 from this quotient to get est quotient #1 .
Multiply c times est quotient #1 (producing yet another 128 bit number).
Subtract c times est quotient #1 from the 128 bit product of a x b
Repeat this process again, with est quotient #2.
At this point, c will go into the result 1 or 0 times.
I just reread what I wrote, I was being special. I blame it on lack of sleep.
Yes, yes, and yes. I don't think I could write them correctly and efficiently without a reference, but I understand the basic principles and may have coded some of them (not recently).
My question is essentially, "What's an efficient multiprecision modular reduction/division algorithm for two-word numbers?".
Good point. Maybe I should just buckle down and try this in Intel assembly (gcc-style).
I'm going to have to think about this, breaking it down to 64-bit steps. Thanks.
