Thread Closed
Is Hom(Lambda^k(V),Lambda^(k+1)(V)) and element of End(Lambda(V))?
Share Thread Thread Tools
Dec29-06, 10:36 PM   #1
Sorry I don't know how to write in symbols so I'm using Latex codes, anyway,
the question is as in title:
Is an element of Hom(Lambda^k(V),Lambda^(k+1)(V)) and element of End(Lambda(V))?
In words, is an element of the homomorphism between k th grade exterior algebra over V and k+1 th exterior algebra over V also an element of endomorphism of exterior algebra over vector space V?
I appreciate your help
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec29-06, 11:33 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
What is the domain of an element of
Hom(Lambda^k(V),Lambda^(k+1)(V))?
End(Lambda(V))?
Can a function have two different domains?
Dec30-06, 04:44 AM   #3
Recognitions:
Homework Helper Homework Help
I'm afraid I'm going to disagree. Let n be the dimension of V. Then canonically
[tex] \Hom(\Lambda(V),\Lambda(V))= \oplus\Hom(\Lambda^r(V),\Lambda^s(V)[/tex]
0<=r,s<=n.
Thus any element of the vector space Hom(\Lambda^k(V),\Lambda^{k+1}(V)) is canonically an element of End(\Lambda(V)).
The question boils down to: if x is in X, is x also an element of X\oplus Y, and it is. I think the function notion is very misleading at times.
Dec30-06, 05:09 AM   #4
Yes I agree with what matt grime said,
When I carefully read the text again it said,
"Let V-->Hom(Lambda^kV, Lambda^(k+1)V) be the action of V on LambdaV"
and since action of V on LambdaV is precisely the homomorphism between V and End(LambdaV) I can see that an element of Hom(Lambda^kV, Lambda^(k+1)V) is precisely an element of End(Lambda V)
Thank you for your help anyways
Dec30-06, 12:12 PM   #5
Recognitions:
Quote by matt grime View Post
But being canonically an element isn't the same as actually being an element... which is what I had asumed the OP meant.
And there's a problem with this argument: it would also prove, for example, that every 1x1 real matrix is canonically an element of any group of mxn real matrices.
I had also assumed End(\Lambda V) was the ring of algebra endomorphisms, not vector space endomorphisms. The canonical embedding you describe doesn't live in the subset of algebra endomorphisms.
Quote by precondition View Post
I'm pretty sure that the text doesn't mean
For any particular k, V-->Hom(Lambda^kV, Lambda^(k+1)V) is the action of V on Lambda V
but instead means
The collection of all V-->Hom(Lambda^kV, Lambda^(k+1)V) constitutes the action of V on Lambda V
which makes more sense, because to have an endomorphism of V, you have to know what happens to every Lambda^j V. (The canonical embedding matt describes for a particular k assumes the zero map on every j unequal to k)
Dec30-06, 12:57 PM   #6
Recognitions:
Quote by Hurkyl View Post
It doesn't prove that at all. There is nothing canonical about the description you just gave. Anything that invokes matrices is by definition not canonical. Although I agree it is a wooly question: if 1 is a real number is 1 an element of C?
Dec30-06, 01:11 PM   #7
Recognitions:
Canonically,
[tex]
(\mathbb{R}^m, \mathbb{R}^n)
\cong \bigoplus_{\substack{1 \leq i \leq m \\ 1 \leq j \leq n}} ( \mathbb{R}, \mathbb{R} )
[/tex]
I guess my real point, though, is that it's an abuse of language to say "An element of X is an element of [itex]X \oplus Y[/itex]", since what we really mean is "we have an embedding [itex]X \mapsto X \oplus Y[/itex] which we will invoke implicitly as needed". Using an example with a repeated summand was just an indirect way to get at this.
Dec30-06, 01:35 PM   #8
Recognitions:
I never have liked canonical. How are you picking out a summand, canonically? What if I change bases? I then change that decomposition. If you start writing down copies of R like that it stops being canonical in any meaningful sense. The fact is that a 2 dimensional real vector space is not canonically isomorphic to R\oplus R.
The decomposition of Lambda(V) does not depend on any choice of basis in V.
Thread Closed
Thread Tools
Similar Threads for: Is Hom(Lambda^k(V),Lambda^(k+1)(V)) and element of End(Lambda(V))?
Thread Forum Replies
De Broglie wave length, lambda=h/mv Quantum Physics 4
value of lambda Cosmology 16
Lambda QCD General Physics 3
Einstein and Lambda General Physics 1
lambda interacts with gravity to give expantion Special & General Relativity 5
